1 members (ronsway), 185 guests, and 2 robots.
Topics128,167
Posts1,057,019
Members48,458
7
7 Offline
I need a 4 speed transmission for my 1956 1.5 ton 4100 truck with the 235 six engine. Does anyone know the compatibility years for this transmission? I have access to a 1948 2 ton Chevy truck transmission and wondered if it would bolt up to my 56 truck?
Big Bolt Forum Moderator
if they are both SM420 transmissions, it should bolt up. I am not sure if the 48 had an open drive shaft or not. You may need to change the rear bearing retainer plate that also holds the park brake.
Mike
Per my Parts Books, Transmission Case casting number 591953 was used from 1948 thru 1963.
Note, you may have to transfer your parking brake if it's different or not there.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
I have a....
Private buying/selling should take place in email and/or Private Message.
