0 members (),
140
Mod | | | Forums66 Topics128,105 Posts1,056,541 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | I have a 1958 GMC 1/2ton truck with a GMC302 backed by a 3speed trans with manual OD
Wanting to add a/c. Anybody already done it? Do they make a a/c bracket that will work?
Any advice is appreciated.
Danny 1958 GMC stepside GMC 302 six cylinder 3 speed OD trans
| | | | | Joined: Feb 2004 Posts: 29,835 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,835 | The 302 will have enough torque to pull an A/C compressor without any noticeable loss of performance. Check someplace like "Vintage Air" to see if they make a compressor adapter for the GMC engine (probably not). I've seen the smaller import car compressors mounted where the generator usually goes, with the generator or alternator piggybacked on top and driven by the second groove on the compressor pulley with a short belt. Jerry
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Yep, I think Patrick used to offer those, perhaps someone on here will have a picture for you.
Ed
| | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | Yeah I've seen those. They are for the 235's. I do not know if they make one for the gmc 6ylinder
| | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | Anybody added a/c to their GMC6? how did you do it?
| | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | Found this on evilbay. Looks like you’ll need an alternator and dual groove pulley. https://www.ebay.com/itm/10071-AIR-CONDITIONING-ALTERNATOR-BRACKETS-FOR-1955-59-248-270-302-GMC-6-CYL/222808573940?_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D2%26asc%3D49917%26meid%3D6777fadf612040009fa04b0e7192b594%26pid%3D100623%26rk%3D1%26rkt%3D3%26sd%3D322569067118%26itm%3D222808573940&_trksid=p2047675.c100623.m-1 brackets
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | If you have a lathe or access to one I use a serpentine belt drive set up that is clean looking and works well. Just cut the "V" groove off the factory pulleys and welded on the flat serpentine ones. Have one set up on a 57 3100 with a 235 and another on a 37 straight eight Buick. Both have been trouble free. Finished pulleys MUST be true. The picture was in the fabrication stage so just a single bolt or vise grips holding things in place but it give one the idea of whats needed. Much better IMO than multiple belts. [img]https://s18.postimg.org/y11n7fg8l/IMG_4179.jpg[/img]
Evan
| | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | Serpentine idea is nice but I am staying with 3/8 belt setup.I like seeing ideas; as not sure how I am going to do mine.
| | | | | Joined: Sep 2013 Posts: 1,366 'Bolter | | 'Bolter Joined: Sep 2013 Posts: 1,366 | coilover, on the ebay ad I particularly like item 3) Does not require 3 hands to tighten. Always a nice feature!!
RonR
1951 3600 with Clark flatbed, T5, 4.10 rear 1970 340 Duster 1990 5.0 V8 Miata (1990 Mustang Gt Drivetrain) 1964 CJ5
| | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | I see that the one on EBay requires a double harmonic balancer.What Double groove hb can I use on the 302?
| | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | Davis Speed Equipment has what I need to add A/C to my gmc302. He has a lot of brackets for the 6 cylinders. Not too many people sell parts for the 6cylinders.
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | I got a 2 groove hub for a 292, had to trim slightly, lengthwise to line up w/ pulley, made in Australia, might find PN somewhere if you need.
Ed
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | My AC system on a 261 ci motor (very similar set up as your GMC) went like this; use a single belt to run water pump and also compressor which is now mounted where generator was. The compressor has a double pulley, this is where your second small belt comes in, from second groove on compressor use short belt to alternator which is mounted directly above ac compressor. Even with ac off, this set up will drive alt/water pump all the time. We made our own brackets, one to mount compressor and other to locate the alternator which is above the compressor and to the side of your thermostat housing. There are several vendors now that have the brackets for this motor, check Alan Grove and possibly Chevs of 40s etc. Best of luck Take a look at this set up, pretty much like mine. http://www.alangrovecomponents.com/images/New_Images/Large/301LTrial.jpg
