Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
5 members (klhansen, NJC, UnclePaddy, Guitplayer, 1955 1 Series), 88 guests, and 3 robots.
Topics128,281
Posts1,058,460
Members48,490
#1252608 01/26/2018 5:31 PM
Simple question, but maybe not a simple answer:
Does a thermostat have a shelf life, and if so, any thoughts on how long it is?
Ultimately, it's not a big deal to replace one, just trying to avoid an issue if there's reasons too.
1947 3100 Advanced Design
Never, never, never, never give up. - Churchill
Sir Searchalot
Sir Searchalot
The only perishable item is any rubber gasket. The spring is more or less at rest on the shelf. The other metal items do not perish. As you said, they are so cheap that if you have an old thermostat (NOS), it's not worth taking a chance. The expandable compound inside (like wax) could degrade I suppose. As far as how long, can't say, depends on it's storage environment and quality of any rubber. No rubber= long time.
You have brought up one of my pet peeves. Bunch of NOS stuff on Ebay and elsewhere. Many people get all tingly over NOS..... Shocks, Carb Kits, all kinds of parts that contain rubber, plastic, gaskets, seals, insulation, fluids, diaphragms, compressed or extended springs, etc. Those compounds/materials will be no good after 50 years. They were not as good as todays materials. So be advised about NOS. Make sure you won't be relying on them if they have perishable/degradable materials or are made with an item that "takes a set"/looses it's "memory. NOS=NFG.
Bartamos,
It's a Robertshaw stat. Doesn't appear to have any seals. It's installed and cycled well during the check out drive. We'll see how it goes. Holding get on to the old one (lower temp) just in case.
Sir Searchalot
Sir Searchalot
10-4
