7 members (Cletus1950, TexasJim50, klhansen, Otto Skorzeny, Jon G, 2-Ton, 1 invisible),
80
Mod | | | Forums66 Topics128,281 Posts1,058,460 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 240 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 240 | Simple question, but maybe not a simple answer:
Does a thermostat have a shelf life, and if so, any thoughts on how long it is?
Ultimately, it's not a big deal to replace one, just trying to avoid an issue if there's reasons too.
1947 3100 Advanced Design
Never, never, never, never give up. - Churchill | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | The only perishable item is any rubber gasket. The spring is more or less at rest on the shelf. The other metal items do not perish. As you said, they are so cheap that if you have an old thermostat (NOS), it's not worth taking a chance. The expandable compound inside (like wax) could degrade I suppose. As far as how long, can't say, depends on it's storage environment and quality of any rubber. No rubber= long time.
You have brought up one of my pet peeves. Bunch of NOS stuff on Ebay and elsewhere. Many people get all tingly over NOS..... Shocks, Carb Kits, all kinds of parts that contain rubber, plastic, gaskets, seals, insulation, fluids, diaphragms, compressed or extended springs, etc. Those compounds/materials will be no good after 50 years. They were not as good as todays materials. So be advised about NOS. Make sure you won't be relying on them if they have perishable/degradable materials or are made with an item that "takes a set"/looses it's "memory. NOS=NFG.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Mar 2012 Posts: 240 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 240 | Bartamos,
It's a Robertshaw stat. Doesn't appear to have any seals. It's installed and cycled well during the check out drive. We'll see how it goes. Holding get on to the old one (lower temp) just in case.
