5 members (CuzzFuzz, 39Master85, Ponchogl, WICruiser, Otto Skorzeny), 82 guests, and 3 robots.
Topics128,090
Posts1,056,345
Members48,442
DLBrooks
DLBrooks
This may be listed elsewhere and maybe no one cares but I disassembled a GM 1946 -- 4 speed crash box and have the following bearing list:
Input shaft to mainshaft pilot -- Open Roller cage - no number found - have not found- .875" ID x 1.25" ODx 1.5 " long ---- I need to clean up the mainshaft pilot so I will lathe it to .75" and hope to use a Koyo HJ-122016 open needle roller bearing. It has an outer case that may solve any female input shaft issues. .75"x1.25"x1" long
Input shaft bearing -- FAFNIR 209K
Rear Mainshaft --- New Departure 3307
Front Countershaft --- Hyatt ORB 1206
Rear Countershaft ---- Hyatt ORB 1207
Feel free to update or correct this list and add any cross references, etc.
1959 GMC 100 Fleet
Follow in the DITY
Thanks for posting this list, it will be helpful to some.🛠
DLBrooks
DLBrooks
The fit of the Koyo is just a bit more than a slip fit into the input shaft... nice. Should be able to pull it easily with a pilot bushing puller. Again I will lathe the mainshaft pilot to .75".
https://67-72chevytrucks.com/vboard/showthread.php?p=8172090#post8172090
There are probably some of the originals nos open roller cage bearing out there.
Has anyone removed the rear mainshaft bearing -- new departure 3307--- with a bearing seperator and not destroyed it? Or does the shaft snap ring push off with the bearing?
1959 GMC 100 Fleet
Follow in the DITY
DLBrooks
DLBrooks
Does anyone know if the crashbox 4 speed was left natural casting color from the factory or was it painted a color?
Gray?
If it was casting color I may clear coat it.
1959 GMC 100 Fleet
Follow in the DITY
