2 members (crenwelge, 1 invisible),
181
Mod | | | Forums66 Topics128,196 Posts1,057,395 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Well to day is one of those washouts, I've spent most of the day on the confuser a lot of that time was trying to find out about Dupont paints and I never did find any answers. Does Dupont still make Lucite? Where does one find a Dupont retailer? Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | dupint page Many bodyshops mix their own paint these days, so body supply retailers are dryimg up like a grape in the hot sun. There is one near me, used to be a half dozen. brian | | | | | Joined: Jul 2004 Posts: 427 Shop Shark | | Shop Shark Joined: Jul 2004 Posts: 427 | Ha Denny, There's one in rockford. NE corner of Alpine and Sandyhollow just off the bypass. 815-874-9866 is their # | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | That's exactly what I mean Brian. I just spent twenty min. there and walked away empty handed. Denny Graham Sandwich, IL
| | | | | Joined: May 2006 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 119 | According to the Dupont website they sold the lucite line in 1993. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Thanks doc, where did you find that??? I've been lookin on and off for days and can't find any usfull information on their d%$# web sites. I guess that's another one of the reasons that everone I talk to now days is using PPG. Back in the day when I was in the automobile game Dupont was King, but then again so was DeSoto and Sinclair. Denny Graham
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | My local FLAPS, an Auto Supply affiliate, handles PPG & I have had great success(& I am really a novice @painting), they will mix anything, prices are very fair(if you buy alot thye give you body shop discount). No problems matching & mixing my 43 yr old codes. PPG's website is easier to use IMO also. PPG used to be Ditzler, IIRC, Brian | | | | | Joined: Jul 2005 Posts: 169 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 169 | Why do you want lucite? Old technology that is better served in the thrash can. | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | how about the drive of the #24 car... he should know a little........  Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Jan 2007 Posts: 79 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 79 | Denny, PPG owns the Lucite brand now. I believe they dropped the automotive finishes line and kept the house paint line.
1949 "Heinz 57"
| | | | | Joined: May 2006 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 119 | Dave is correct. I went back and read the info on the Dupont site and they sold the automotive line in 1983 and the house paint line in 1993. Also there is a Lucite International but they are mostly into polymer plastics and resins. I haven't found any place that sells anything to do with Lucite lacquer. What are you trying to accomplish? Maybe we can find you another solution. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Dupont's out, PPG's in. Forget about it guys. Denny G.
| | | | | Joined: Jul 2006 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 44 | Denny, we have a DuPont store here ,I go there every day. Lacquer has been off the market for awhile now but I have seen some no name brands advertised. My jobber is a good friend ,in fact is building a 47 show truck. Let me know if I can help.
Popa Kents Body Shop
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Thanks Papa Kent, I was thinkin' that the original AD interior paint might have been Duco early on and then toward the end Lucite when GM switched over to it in the early 50's. I've got a '50, 3604 and have tested the seat side garnish panels with lacquer thinner, and it won't touch it so I’m assuming now that it's enamel. I have a quart of PPG CPC ALK-200, (Commercial Performance Coatings, alkyd modified acrylic enamel that I got from JC that I was holding off on using cuz I thought the interiors were done in lacquer. The side panels are out of the sun and are probably the best preserved original color on the interior so Tuesday I dropped one of them off at the PPG dealer for them to mix me up another Qt. NG!! They can only mix the Industrial coatings in gallons, and I sure don’t need a gallon right now. So I said Omni? and he said NG, for enamel I needed Delstar. I’m so confused!!! My thoughts were originally to have them scan the panel, give me the formula and mix me up a quart, thsn later if I need more I could simply have them refer to the formula. NGGGGG!!! To scan it an give me a formula would add an extra $75 to the Quart. He explained that the scan was pretty rough and usually off by a bunch and they had to adjust the tint by hand. To come up with a formula they had to count or measure everything that was added to get the tint correct and record it all for the final formula. So, I’m gonna get a one time mix of a quart to match the panel, in a Delstar Enamel. I wonder if that would mix OK with the CPC enamel??? Just in case I run short with one of them. Next thing I got to figure out is if I can spray this plain or if I need (don't want) a hardener, what to use for reducer and clean up and what use for a flattener so I the glare doesn't blind me. Denny Graham Sandwich, IL
| | | | | Joined: Feb 2006 Posts: 428 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 428 | Denney, first find a new paint supplier. Every paint supplier in my town said that if I had a 2x2 chip of good paint they could color match it for the cost of a 2 ounce sample. I also purchased the correct paint for my 52 interor from Chevs of the 40s. As soon as I do a test panel, and get it color matched I will post the formula on this web site. I don't know why somebody hasn't done this before, so don't despaire you should have the code in the next couple of weeks. Jimmie. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Maybe I confused ya all again, they are gonna mix me a quart of paint, but they aren't gonna give me a formula unless I pay them $75 more. Sounds like that is the standard procedure I'll be looking forward to what you find out Jimmie, are you using PPG and if so what system? Denny Graham Sandwich,IL
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | they are gonna mix me a quart of paint, but they aren't gonna give me a formula unless I pay them $75 more Denny, That's not standard in my area. The PPG jobber gave me all formulas from color scans. Have you called PPG for a formula (usually it is what they call an "offset" formula)? Tim These phone numbers are old, but I got every color code (and offset formula) I needed (several years ago): 440-572-6100 PPG Color Library 440-572-6111 PPG Tech Services Refinish (gave me the phone number for the Color Library) | | | | | Joined: May 2006 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 119 | Sounds like they are trying to get to you on the formula. The people I deal with will scan it and give me all the info I need for no charge. | | |
