6 members (sron48, Charles in CA, Gray_Ghost, 66flea, Wally / Montana, dt235sd), 72 guests, and 1 robot.
Topics128,050
Posts1,055,757
#1251943 01/21/2018 8:58 PM
1 Offline
I want to maintain the 18" wheel size, yet get a custom look. I dont know how the dipped ones hold up, but I found alot of options within the semi truck world but obviously an adapter would be needed that probably doesnt exist. Has anyone else done a custom 16-18" wheel? What'd you do?
An idea you might consider.... My 55 2nd truck came with a God awful rusty chrome and red small wheel. I found a stock one on ebay and repaired the cracks and gave it a few coats of Rustoleum. Then added a black wrap cause I figured the paint would wear off quick. That was almost 5 years ago and the wheel is still going strong. I like the original look, altho my truck is a hotrod, it appears mostly stock.
I bought a new reproduction 40 Ford style wheel from southern Rods and parts. Looks very period correct on my Truck , 16 inch. My Truck is a hot rod as well , so keeping everything stock is not an issue , just like it to look period correct for the Trucks age.
Tom
1950 3100
I did the same thing to my stock steering wheel on my old '63 back in the late 70s/early 80s. It was still on it when I sold the truck in 1987.
Sir Searchalot
Sir Searchalot
There are some very nice looking original wheels from the 60's and 70's. Bel Air, Impalla, SS, Buick, Cad, Oldsmobile... Splines are all the same.
Wheels like this
I have a 53 3100. I wanted turn signals so I took a wheel and turn signal mech off a 57 truck. same size column as my 53. all fits nicely except the 57 wheel is dished 4" so i had to shorten the shaft and housing. I epoxy and painted the wheel $20. Wheel and turn mech $20. local welder column work $30. I'm using electric power steering but like the look of the big wheel.
Moderated by  ndkid275, Phak1
