3 members (Deegs53, Gray_Ghost, Steelonsteel), 97 guests, and 3 robots.
Topics128,129
Posts1,056,700
Members48,454
I know that the GMC engine is a bit longer out front.
What is the best way to modify the front crossmember to accept the early GMC motor mount so this 302"can find a new home.
Thanks Tim, I.ve read that article several times. Was hoping for a little more detail than "cut from truck mud flaps".
Geez, do I have to reinvent the wheel ?
Maybe take photos for a tech tip.
You could swap a GMC crossmember, and if necessary put a spacer between radiator support and crossmember.
•1952 Chevrolet 3800 pickup
---All pictures---
Thanks Grigg for the response.
That looks to be an awful lot of work. That may be the absolute "proper" procedure, but hopefully I can fabricate something a little simpler. It's only 2"s.
