0 members (),
128
0
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2004 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2004 Posts: 40 | I typically use a mixture of 50/50 prestone in the old trucks and leave it at that. I do not read concentration regularly as I never had an issue. They are currently in storage in upstate New York where the temperature got down as low as -20 one evening. Like many I never anticipated this unusual cold. if the antifreeze were a bit "weak" what's the reality of damage?
Thanks | | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | I wouldn't concern yourself with 50/50 | | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | the garage probably didnt get down to -20 anyway. | | | | | Joined: May 2015 Posts: 11,024 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,024 | 50/50 Ethylene Glycol/Water solution is good down to -34F IIRC. Even below that it doesn't form solid ice, but more of a slush. Same should be true of a weaker solution. If you started with 50/50, there isn't anything that should significantly change the concentration.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | My concern about anti freeze is, as it ages does it still give the same protection? | | | | | Joined: May 2015 Posts: 11,024 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,024 | Should be fine. The only thing it loses is it's ability to inhibit corrosion. Freeze protection doesn't change.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Apr 2016 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2016 Posts: 52 | I live on a farm with several cars, trucks, tractors, and a few other water-cooled machines. I used to "temporarily" run straight water after a repair in warm weather, "just to make sure nothing is leaking". Then I would forget what did and didn't get anti-freeze, until the first bitter cold night at about 11pm when I would panic and start going from garage, to shed, to barn with a flashlight and hydrometer. Now no project leaves the shop without 50-50. It ain't worth the worry | | | | | Joined: Oct 2004 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2004 Posts: 40 | That's kind of what I was thinking myself Even at a slightly "weaker" mixture it would likely turn slushy before a complete freeze | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | I froze my 5.3 GMC earlier in November. The waterpump was leaking like a sieve and the truck was going to soon be scrapped. So I added water every day til I was gone for a few days. The engine froze up solid, threw the serpentine belt when I tried starting it. I put it inside, got the belt back on and after a while it started again, no cracked anything. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 |
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Back in the 50's my grandfather ran water in his late 40's AD pickup. When the weather got cold he'd pour a bottle of rubbing alcohol in the radiator and throw an old quilt over the front of the hood and grille. It worked for years.....then bang, one year the block split down the side. Some stop leak and he drove it for another two or three years. ...those were the days.
I agree with redwing, depending on where you live, that a 50/50 mixture is in order and forget it. To save money though I buy the concentrate and mix my own. Kind of like 2 gallons for the price of one. | | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | I was watching one of those car resto channels on the boob tube and someone said not use tap water when mixing concentrate because it contains minerals which can help corrosion. They said to use distilled water which is supposedly pure H2O. I don't know if I should believe any of that mumbo jumbo. I always used water outta the garden hose. | | | | | Joined: Dec 2008 Posts: 899 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 899 | I was watching one of those car resto channels on the boob tube and someone said not use tap water when mixing concentrate because it contains minerals which can help corrosion. They said to use distilled water which is supposedly pure H2O. I don't know if I should believe any of that mumbo jumbo. I always used water outta the garden hose. "BELIEVE"
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I used water most of my life but as radiators "changed" I decided to use distilled water. Since I use it in my C-Pap machine I just pick up an extra gallon or two. I can get it most places here for a buck a gallon, no more than $1.10 plus, its good if you have to add to a battery. .......At my age anything to prolong the life of one of my vehicles means I may not be the one who has to fix it.! | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | My water is very hard with minerals, usually take water out of the dehumidifier and pour it in the rad. | | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | [
"BELIEVE"[/quote] Times 2 1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | My water is very hard with minerals, usually take water out of the dehumidifier and pour it in the rad. Thanks for the good idea, Leo | | | | | Joined: Feb 2004 Posts: 29,760 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,760 | That drip from the heat pump drain is moisture condensed out of the air. That's about as mineral-free as it gets (if you really believe in that load of fertilizer some people are shoveling!) Jerry
| | | | | Joined: Aug 2011 Posts: 22 'Bolter | | 'Bolter Joined: Aug 2011 Posts: 22 | | | |
