1 members (Eileen), 271 guests, and 2 robots.
Topics128,101
Posts1,056,181
Members48,436
#1251534 01/18/2018 8:24 PM
This references a thread I posted a short while back regarding water in oil. I am expecting my head back soon. It has been magnafluxed, inspected, etc. That wasn't the problem. Before setting the head back on the block, I would like to know if there is an "easy" way to check for a warped block surface. How flat is flat?
Bob
BobS46
8
8 Offline
Years ago, I had a warped head that I diagnosed with a framing square. It was warped pretty bad, but i would think that the square might be a good place to start.
-Tim
'51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
I use a carpenter's level and feeler gauges. It has a nice machined surface. If I have doubts about the surface of the level I just turn it around and measure again. If the level's surface was not true, the apparent warp would change.
1951 1 Ton Completed
Search Ebay for "machinist's straight edge". The prices are ranging from less than $20.00 to over a thousand, depending on how precise you want to be. It looks like some in the $40.00 range might be something I'd be interested in having, particularly the 3-sided one from Belarus.
My engineer brother has a machinist granite slab he puts a lot of confidence in. It'd sure be inconvenience to turn an engine upside down and check the block though! The head, it'd be great.
RonR
1970 340 Duster
1964 CJ5
It would also probably be good for checking a straight edge or a framing square, for straightness.
Brian
1955.2 3100 Truck
Where did you find an engineer with any real hands-on experience? The ones I've encountered most of the time (including my brother) live in their own little fantasy world that has nothing whatsoever to do with actually working for a living!
Do a search for "machinist straight edge" and you will get lots of hits ranging from $50 to $500. Our Starrett was around $200 several years ago but we got one that could do straight eights. Always hang one vertically from one end when not in use.
Evan
He's a hands on guy. Specs and installs a lot of automated robotic type equipment, writes a lot of the operating code as well. Often times he's the guy with the greasy coveralls on new installations though.
It's funny he's little bro, middle bro and I are very seldom allowed to do MUCH at all so-far as helping on his personal around the place projects. Our standard of "good enough" usually isn't!
RonR
1970 340 Duster
1964 CJ5
is a good video on checking the deck.
1961 ford f500
1953 3100 five window (https://www.facebook.com/1953-Chevrolet-5-window-1533405913413610/)
1955-2 3200 big window (https://www.facebook.com/Leep3200/)
55yrs as a mechanic and retired. (kind of)
