1 members (baldeagle),
80
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2003 Posts: 151 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 151 | I've got my '46 Panel almost done. Now I'm lost with this goofy hood cowl windlace/weatherstrip. I got it from Amer. Classic and I've checked others and they are all the same part. But I just don't understand how this is supposed to be applied. I've got four pieces of weatherstrip, two long(48") and two short(10")and the clips/screws. I see the groove and screw holes across the top and down the side of the cowl. But when I place the strip there it is clearly higher than the body line. And I have no idea at all of where the two 10" pieces goes. I've checked everywhere I can find and can not find a good drawing or pic to show me. Can somebody help me out with this mess.
David Just a firefighter, Cleverly disguised as a responsible adult '46 1/2 T Panel
| | | | | Joined: Jul 2005 Posts: 161 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 161 | I had the same issue with the weatherstrip I got from ACT for my 46 1/2 ton. I ended up not using the small strips. I took the long strips and set them in the groove on the truck to eye it up. I used the pre-existing holes that were in the grooves (I had three on each side) to use screws through the weatherstrip. I also used a weatherstrip adhesive on the strip as I put it down. It may not be how it was done originally but it is on there nicely and the hood shuts easily and snugly.
1946 Chevy Pickip
