1 members (5 Window 9434), 68 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#1251403 01/17/2018 7:07 PM
Hi all,
I have a 1950 1/2 ton. Where does the groundcable attach to the chassis?
Thank
skipper
Originally:
1. battery to frame
2. frame to clutch-housing
3. optional: head to firewall brace attachment joint (recommended in some years with radio option)
Which hole in the frame is used for the cable? I mean the location, there are many holes
Choose a hole that suits your fancy.
For example:
- place the battery so the positive lead (that goes to starter) is orientated to the front of the truck.
- the negative lead will be rearward of the battery box.
- use a hole in the side of the frame rail that can be easily bolted into.
However, I went for overkill on my 6v Suburban and ran the ground cable to a starter bolt.
If you have a 6v system, use no smaller/thinner than 2 gauge cables/straps - I use 00 gauge cables.
Crusing in the Passing Lane
If a GMC half ton, it will be pos. ground.
Ed
Also, be sure to sand or grind the frame down to bare metal where you bolt the cable on.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Also, use a conductive anti-oxidant grease on the bare/shiny metal on the mating surfaces.
For the perfectionist;
1947-1954 Factory Assembly Manual
Battery Cable & Ground Strap Instruction (Attached)
LD Left Hand Drive Shown
Electrical Contact Grease NO-OX-ID "A-SPECIAL
xfiles
NO-OX-ID label says it is food grade. Maybe it is chicken fat, beef tallow.
The term “food grade” is an adjective that means the material or product at hand is either fit for human or animal consumption, or, more commonly, is at least permitted to come into contact with food. I think the latter of the two is what’s implied in the No-Ox-Id label. Don’t think I want to eat a spoonful of the stuff.
Chuck
1941 Chevy coupe
1938 Chevy coupe streetrod
When I want to fry some eggs and I'm outta butter I squirt a little in a pan. Yum Yum, Not smile
At least my innards won't corrode.
