| | | Forums66 Topics128,120 Posts1,056,649 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | Hi, On an original temperature sender for a 1950 truck what size is the port drilled into the head? 3/8"?
I have an 848 head on a 261 (1962 head and engine) with an enlarged hole for an electric sender. The 62 hole is 1/2". However, I used a bushing to get it from 1/2" down to 3/8" in an attempt to use the original gauge sender and the old '50 sender is still flopping around in the 3/8" hole.
Anybody else have this issue? | | | | | Joined: Feb 2004 Posts: 29,836 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,836 | The early temp sensor hole is not a pipe thread- - - -I believe it's the same as a 5/8" coarse thread bolt- - - - - -5/8-11, maybe? The threaded bushing that's built onto a mechanical temp gauge capllary tube threads into an early head without adapters. Aftermarket direct reading gauges have one of those fittings included in the hardware kit that comes with them. Jerry
| | | | | Joined: Jan 2013 Posts: 2,236 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,236 | I just figured out my 216 is 5/16. Not sure about 261 heads | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | This adapter/reducer has worked on my later 235s/261s.I posted a message incorrectly - Martin noted this below - I moved the message to the correct thread. Sorry
Last edited by tclederman; 01/14/2018 3:53 PM. Reason: incorrect follow-up message has been deleted
| | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Fox, Is your 261 a Canadian engine as mine is? I also have a very big threaded hole in mine, not sure the size but it has a reducer for the sending unit. | | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | Tim, Yes that's what it is. However I just went down to the hardware and got a pipe bushing. 1/2 to 3/8 and it was sloppy. As Jerry said, it must be a regular thread. Perhaps I'll grab a 1/2 to 1/4, drill it out and then tap it to fit if I can't find a proper one locally.
Panel, yes it's Canadian with the big port. I'm not sure of port size on earlier Canadian head for a 261.
| | | | | Joined: Feb 2004 Posts: 29,836 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,836 | "Danger, Will Robinson!"- - - - - -If you drill and tap, you're going to be making a big mistake and probably ruining the head. The 5/8-11 adapter has a flat bottomed area for the sensor bulb to seat against, and the straight thread above it. Unless you have a way to machine an adapter with that shape, there won't be any flange for the bulb to tighten against. An aftermarket mechanical gauge with a sensor bulb costs just a few bucks, especially if you get a cheap one on Ebay, and it will have all the adapter hardware you need. Even if you don't use the gauge, you'll be able to install the one you're working with. Jerry
| | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | Oh no Jerry, I agree with you. I won't be drilling the head. I will be making my own bushing. I will be drilling and tapping into a bushing to get the old bulb sensor to fit. Then install that into the head. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | The threads on an original 1950 mechanical senson is 5/8-18 If your head is 1/2 pipe you can use the adapter tim linked to above Napa auto carries the apapter also ...example... | | | | | Joined: Feb 2004 Posts: 29,836 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,836 | Yep- - - -5/8" fine thread- - - -not coarse! Jerry
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Probably the only place you will ever find fine threads used, in cast iron, on a Stovebolt.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Feb 2004 Posts: 29,836 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,836 | It was pretty common on Brit sports cars back in the 1950's. Triumph, MG, Jag, etc. Jerry
| | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | I noticed the "shoulder" inside an older spare head I had in the shed. If I go this way, I will have to stop short with the pilot hole and then use a bottom hole tap to do this.
Or do the simple, easy thing and get the right bushing! Haha! Thanks for the links guys. I'll be doing this.
Thanks for the measurement too, fellas. I noticed that when I was in the shop.
| | | | | Joined: Aug 2000 Posts: 248 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 248 | Jerry raised a very important issue..... Unless you have a way to machine an adapter with that shape, there won't be any flange for the bulb to tighten against.
The original early 216 engine the sender has that special flange that no regular adapter will allow you to seal the sending bulb. The early flanged senders are easily recognized by the four sided bolt top...... our solution when working on the 261 is to buy the cheap aftermarket temp. gauge JUST to get one of the adapters in the kit .
Caution: if you over tighten the adapter into the head.... the head can crack........ so far the JB Weld on the thread is holding and has been for a few years.
We have a further complication...... the early military 216 trucks had a steam line connected in that hole and vented just under the radiator cap. It was meant to release air pockets that may have formed inside the 216 heads during very steep descent or climbing. I means having a T fitting with a line to the radiator and the heat sender bulb fitted to the top of the brass t fitting. We first tested them in operation using a clear nylon line and where amazed at the froth that was sent to the radiator....after some time in level position it becomes clear green antifreeze. At that point, the temp line was replaced by a solid steel brake line to the rad.
Bob C Can't remember how to attach a picture!!!!
Bob C. CMP Heaven The Hammond Barn
| | | | | Joined: Sep 2011 Posts: 131 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 131 | Hi Mr. Johnson I noticed this discussion and as I have three 261 engines and was about to order some small stuff I ordered two bushings. So if you are in need in the spring I will send you one. The photo from Classic Parts makes them look like made from stainless.
Remember, Stay warm. Howie
1 1955 Chev one ton. 261 engine
3 1962 Chev c-10 261 engine 4 1966 Plymouth VIP 5.7 GenIII Hemi 5 1966 Imperial Crown Coupe 440 engine | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Fox, if you want to buy one in Canada I think Bill's Truck Shop here in Ontario would carry them. They generally are pretty good at sending them out pretty quickly. | | |
