6 members (Otto Skorzeny, Ridgeback, klhansen, MNSmith, pdlightning, 1 invisible), 80 guests, and 4 robots.
Topics128,022
Posts1,055,373
Members48,420
#1250494 01/11/2018 6:58 PM
So, I have a GMC 1 ton dually. 4 speed tranny. I'm looking for a pto to go on said truck.
Are all pto units the same for that time frame ? If not how do I go about finding the correct one ? thanks, Charles
I just finished a 1946 chevy pickup street rod
now on a 1950 chevy 3100
also a GMC 220 with duals
and a 1948 chevy 2 ton
Charles Pretzer #1250498 01/11/2018 7:16 PM
Crusing in the Passing Lane
Year of truck? SM-420 or 465?
Ed
Charles Pretzer #1250519 01/11/2018 10:59 PM
I don't know. how do i tell the difference?. one is in a 1 ton and the pto I'm looking at is from a bigger truck, not sure which model
Charles Pretzer #1250527 01/12/2018 12:37 AM
https://www.novak-adapt.com/knowledge/transmissions/manual/
The 465 has some fins or webs cast on the case, the 420 is pretty smooth.
PTO should fit any of same model transmission it is removed from.
For interchange between models, if any, check PTO manufacturers literature.
PTO openings are pretty standard, same bolt patterns. But often need a different driven gear in the PTO for different transmissions, even though the PTO case may seem to bolt up.
Also be aware there are many different kinds of PTO’s for different uses.
1952 Chevrolet 3800 pickup
---All pictures---
Charles Pretzer #1250532 01/12/2018 1:45 AM
If a '50's truck, a 420. Best to figure out first, submit a picture if not sure.
Ed
Charles Pretzer #1250559 01/12/2018 5:00 AM
Big Bolt Forum Moderator
easiest way to differentiate between SM420 and SM465 is the 420 only has one PTO outlet (driver side) and 465 has it on both sides.
Later versions of the SM420 had two horizontal ribs cast into the passenger side of the case so, just because it has some ribs on it, does not mean it is not an SM420.
The link Grigg posted has lots of info on these transmissions and how to identify them.
Mike
69Cuda #1250682 01/13/2018 12:31 AM
I have.....
Mark
Last edited by Grigg; 01/13/2018 2:14 AM. Reason: Please send PM about parts for sale or free
1952 GMC 9430 one ton pickup, a work in progress
1952 1-ton pictures on Photobucket
Charles Pretzer #1250746 01/13/2018 6:22 AM
The best place to find an SM420 with PTO is in the 4100 and larger trucks.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
52_Ton #1250751 01/13/2018 11:42 AM
Originally Posted by 52_Ton
I have.....
Mark
Sorry Grigg...PM sent
Mark
Moderated by  Dusty53
