4 members (1955 1 Series, Sjm, moparguy, klhansen), 150 guests, and 1 robot.
Topics128,195
Posts1,057,370
Members48,469
24601
24601
So as we all know, on the Advance Design trucks, radiator stand is the foundation of the front clip. In removing mine, I expected to find the spacer between the bottom of the stand and the top of the front cross member. I did. I was also expecting to find a washer or two. I didn't, but that's not a big deal. I did, however find the anti-rattle "gasket/grommet" between the bottom of the stand and the top of the two-hole spacer. It appears to be a reinforced rubberized canvas or something -- and not quite the same material as the fender welting, either. Are replacements for this available? If not, what would be a suitable replacement?
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Cut a piece out of an old bicycle tire?🛠 Don’t know if a repro is available or not.
Those pads are reproduced. I don't know if they are as durable as the original ones.
Whatever you go with, the thickness of the pad/pads (some take one in the center, and some take two spread out a bit) and the thickness of the shims is crucial for proper alignment of the rear edge of the hood where it meets the cowl.
Carl
24601
24601
What is the proper name for this? (no guesses -- I can do that for myself, thanks)
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
Y
Y Offline
Radiator Support Cushion, 6.0300, 2209538
3/16" thick
2" wide
1/2" diameter hole
Per the GMC Master Parts Book. After 1952 there appears to be a change. 1954 used shims.
"I always win." Working mainly alone I do not let my trucks win a war. Maybe a battle here and there but never the war.
Robert
55.1 GMC 450 COE
51ish GMC Suburban
Looks like Steele Rubber Products along with all the usual suppliers has Radiator Support Cushions. Sorry, I don’t know how to post links. Maybe Tim or someone computer literate can jump in with a number.🛠
My '57 GMC has a similar anti-squeak pad under the radiator support. I found that a hay round baler belt is almost identical to the original pad. just have to cut a piece to the right size. I had a roll from Tractor Supply that we use to patch our baler belts that I used. It is heavy duty rubber with fiber reinforcement in the middle, and the same thickness.
Ron - - Dusty53
1954 Chevy 3604
I use the side wall from a tire.
_____________
Floyd
If we choose being kind over being right,we will
be right every time.
Knowledge is a poor substitute for experience.
Remember what is precious to another, may not be to you, but it
is precious nonetheless.
1948 Chevy 2-Ton
Thanks Dusty53 just ordered some.
24601
24601
Indeed -- Thanks Dusty -- exactly what I was looking for. And thanks for the thickness info, Yellowsub -- I'll check it when it comes in. Hambone found a mud flap -- It will be interesting to see if the thickness is similar.
GMC guys -- For future reference -- Your radiator support mounting is very different than the Chevrolet one.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
Do you have a GMC support "assembly", John. Does it look like the one I posted above?
The GMC support may be different yes, but that rubber pad, while it may be a slightly different shape, serves the same purpose.
24601
24601
Alrighty then, I have my original question answered, no need to over engineer this.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
