5 members (Wheelie, Gdads51, klhansen, greenie-reddy, 1 invisible), 87 guests, and 3 robots.
Topics128,036
Posts1,055,452
Members48,422
#1250299 01/10/2018 4:11 AM
Can anyone tell me what the original steering wheel was made of on a 1955 1/2 ton chevy pickup. Series 2. Feels like hard rubber?? It had the old ( imitation?) Leather looking wrap on it. It was badly beat so I removed the wrap. Wheel has stickum stuff on it and I'd like to know what I can safely clean it off with. Soap and water won't touch it. Needs a solvent of some kind. Any suggestions for safe cleaning as well?
Thanks for any help.
Jim
1955 Chevy series 2
6 cylinder, 3 on the tree
Short bed, step side
I've taken labels off glass jars and have used WD-40 to dissolve the glue. Takes it right off. Don't know if it would work in your situation, but I'd give it a shot.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
I'd second trying WD-40. Use it on the back first to make sure it doesn't damage the steering wheel itself.
Big Bolt Forum Moderator
I have cleaned them with lacquer thinner. Never had an issue. (55.2, 58, and 59 steering wheels)
Mike
69Cuda #1250399 01/11/2018 12:00 AM
Thanks guys. That's what I wanted to know
Jim
1955 Chevy series 2
There is a product called goof off at your local hardware store. I have used lacquer thinner when restoring them with no problem but I'm repainting them.
once clean, if not shiny enough, you can go over it with some rubbing compound on a rag to shine it back up. (no wax or anything )
Mike
If you have any painting to do further down the line I wouldn't use WD-40, Armor-All, or any silicone containing product. Good products but will leave you fighting fish eyes in paint till you pull your hair out. Have found the wax and grease remover made for cleaning an about to be painted surface or 3M decal remover clean steering wheels well and are paint friendly.
Evan
Read Evan's post three times - this goes for any cleaner, wax, lubricant, "shiney-upper", or rejuvenator.
Normal/standard/original WD-40® Multi-Use Product does not contain silicone; however, by popular demand/ignorance WD-40 sells many other silicone-containing products (one obvious example: WD-40 Specialist Water Resistant Silicone Lubricant).
69Cuda #1250600 01/12/2018 4:19 PM
I like this option. I've never had good luck painting non metal surfaces that get a lot of use.
Thanks to all. Lots of good info here.
Jim
1955 Chevy series 2
