1 members (KEVINSKI), 96 guests, and 3 robots.
Topics128,099
Posts1,056,506
Members48,444
#1250056 01/08/2018 5:54 PM
I set the bed(front panel,sides,rear cross sill) on the frame With bolts in rear cross sill,front sill does not line up to frame holes.First frame holes are 3 1/2" and 6" from cab.Does first cross sill attached to front panel not attach to frame? Does bed wood only attach to front panel? Went back two years on the bed install. section and did not find good help.
Check out Mar-K’s website. Should be some diagrams/instructions there.🛠
Went on Mar-k,found my answer,Thank you.
