| | | Forums66 Topics128,108 Posts1,056,239 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 142 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 142 | I set the bed(front panel,sides,rear cross sill) on the frame With bolts in rear cross sill,front sill does not line up to frame holes.First frame holes are 3 1/2" and 6" from cab.Does first cross sill attached to front panel not attach to frame? Does bed wood only attach to front panel? Went back two years on the bed install. section and did not find good help. | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Check out Mar-K’s website. Should be some diagrams/instructions there.ðŸ›
| | | | | Joined: Jun 2012 Posts: 142 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 142 | Went on Mar-k,found my answer,Thank you. | | |
