| | | Forums66 Topics128,196 Posts1,057,386 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 127 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 127 | Is there a diagram with measurements for installing the passenger side mirror on a 52 gmc 5 window..? | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Jet,
If the GMC is like the Chevrolet truck: on your driver's side look under the dash and see where the driver' side mirror attaches through the cowl - two holes in/through a brace.
Look under the dash on the passengers side and you will see a similar brace with holes (I hope). Punch up at the center of each hole, and then drill for the mirror screw holes.
PLEASE READERS: if I am wrong quickly correct me. I'll check this on my GMC COE tomorrow. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Apr 2008 Posts: 127 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 127 | I did look, and your correct. Should be an easy install. Thanks. | | | | | Joined: Mar 2010 Posts: 10,310 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,310 | Use an automatic set punch from the inside for making the dent come through to the outside. Not much room for swinging a hammer under the cab.
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Use an automatic set punch from the inside for making the dent come through to the outside. Not much room for swinging a hammer under the cab.  As usual, nice one, Carl | | |
