| | | Forums66 Topics128,299 Posts1,058,705 Members48,493 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2017 Posts: 33 'Bolter | | 'Bolter Joined: Nov 2017 Posts: 33 | I pulled the carb off my 54 235 engine to rebuild it and one throttle plate screw was previously twisted off and the other was loose. So I gently tried to tighten the remaining screw and it twisted off too. I got one screw out but couldn't get the other out. Pretty small. Think it could be drilled out? Didn't know if these screws were even available . Maybe someone has an extra base laying around. Any suggestions? | | | | | Joined: Nov 2017 Posts: 33 'Bolter | | 'Bolter Joined: Nov 2017 Posts: 33 | I found some screws on internet, so I may try drilling it out. Anyone happen to know what size these screws are? | | | | | Joined: Nov 2002 Posts: 2,786 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,786 | Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Feb 2000 Posts: 5,274 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,274 | Small brass screw from your local hardware store, 6x32 like Jon mentioned. Also when trying to remove them, drill from the head side of the screw so you don't have to mess with the back side thats been peened over. Most of the time they screw right out. A little heat might also help, and key word is LITTLE!
| | | | | Joined: Nov 2017 Posts: 33 'Bolter | | 'Bolter Joined: Nov 2017 Posts: 33 | My model b carb didn't have 6-32 screws in the throttle plate. They were smaller than that. I was able to find some 6-32 screws at the hardware and drill them out so it worked out. Got the carb kit put in and all back together. | | |
