| | | Forums66 Topics128,092 Posts1,056,043 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 54 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 54 | I have 56 Chevy 1/2 ton and on the back side of the rear axle shaft there is a thin plate held on by the lug bolts. Anyone know the purpose of this plate? | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | If the axle seal were to leak that grease shield should catch it and direct it out a hole in the drum to keep grease off the shoes. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I believe there is a hole in the drum that should be aligned with the hole in the flange. To me this design feature is a bit of wishful thinking. If the seal leaks it will always get to the shoes. | | | | | Joined: Jan 2009 Posts: 54 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 54 | Thanks guys,sounds like it is not real important if it is missing. | | |
