0 members (), 196 guests, and 1 robot.
Topics128,081
Posts1,056,078
Members48,434
#1249760 01/06/2018 3:10 PM
I have 56 Chevy 1/2 ton and on the back side of the rear axle shaft there is a thin plate held on by the lug bolts. Anyone know the purpose of this plate?
If the axle seal were to leak that grease shield should catch it and direct it out a hole in the drum to keep grease off the shoes.
•1952 Chevrolet 3800 pickup
---All pictures---
Grigg #1249792 01/06/2018 8:39 PM
I believe there is a hole in the drum that should be aligned with the hole in the flange. To me this design feature is a bit of wishful thinking. If the seal leaks it will always get to the shoes.
1951 1 Ton Completed
Thanks guys,sounds like it is not real important if it is missing.
