1 members (Peggy M), 105 guests, and 3 robots.
Topics128,151
Posts1,057,000
Members48,460
DLBrooks
DLBrooks
Does anyone know the manufacturer and part number for the replacement mainshaft rear case bearing and the input shaft case bearing? Are there any other parts I need to replace these bearings that can be gotten? thanks
1959 GMC 100 Fleet
Follow in the DITY
If the original equipment bearing is scarce or unavailable, a digital caliper and a progressive size chart from any of the bearing supply places might come in handy if you've got the failed bearing to measure. Timken, BCA, etc. all have standardized bearings that will work in a variety of applications. Sometimes the only difference in an industrial-application bearing and an automotive one is the part number.
