1 members (klhansen),
101
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,151 Posts1,056,999 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2016 Posts: 236 DLBrooks | | DLBrooks Joined: Jun 2016 Posts: 236 | Does anyone know the manufacturer and part number for the replacement mainshaft rear case bearing and the input shaft case bearing? Are there any other parts I need to replace these bearings that can be gotten? thanks | | | | | Joined: Feb 2004 Posts: 29,869 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,869 | If the original equipment bearing is scarce or unavailable, a digital caliper and a progressive size chart from any of the bearing supply places might come in handy if you've got the failed bearing to measure. Timken, BCA, etc. all have standardized bearings that will work in a variety of applications. Sometimes the only difference in an industrial-application bearing and an automotive one is the part number. Jerry
