8 members (Southerntruck, Jon G, GMCJammer51, 3800GUY, Bill Hanlon, Otto Skorzeny, 2-Ton, 50Chevy3100), 157 guests, and 1 robot.
Topics128,102
Posts1,056,185
Members48,436
#1248483 12/28/2017 12:05 PM
2 Offline
My truck has some modifications but for the most part is original. This winter I was working on steering and wondering should I rebiuld my steering box or find a more modern one that might work.Problems I found on the truck were slight ware on right front king pin so I replaced the king pin and bushings and the left bracket that bolts to the bottom of the spindel and goes to the tie rod was loose. Next I would like to do something with steering Box any suggestions?
Crusing in the Passing Lane
Some modern semi COE trucks have canted box, should be close to what you want. '94-'95 GM baby school bus for one.
Ed
I bought an '85 Chevy van 30, (cube van) big disc brakes, dually hubs... 8x6.5" pattern so 16" rims stock, 19.5 rims an option. It has a bolt in IFS crossmember (looks very similar to 73-87 chev truck xmembers) similar to the point of looking like the truck A arms would even bolt to it. (And opposite, use truck x member with these big brakes) The exception is for the steering setup, which looks to me like it would work well in a COE. Someone robbed the steering box out of mine before I got it, but it looks like instead of the steering input to the box pointing aft like a typical box, it would point straight up into the cab. Looks like either a power box or manual box would fit. I'll try to mock it up and post some pictures.
1953 Chevrolet 1100
Grandpa's truck
Story in Big Bolts
1952 GMC 9700
Story in Big Bolts
1948 Chevy Pickup
"Two brothers; two trucks"
In the DITY Gallery
A front end swap is probably a lot more than you were looking to do, but when I figured out how I think this goes together, modern COE steering (/ suspension and brakes) is where my thoughts went... I got it loosely mocked up and took some pics. The steering box is just one I had laying around and is not the '85 chevy van 30 box. I tacked it there with a bolt (all holes line up, just a different shaft on this box so the pitman arm won't bolt on) the frame sections are also just tacked back in with a couple bolts and I put the idler arm back on for the pics. Slightly off topic (as is my reply) but thought I'd add brakes are hydroboost setup...
1953 Chevrolet 1100
Grandpa's truck
Story in Big Bolts
1952 GMC 9700
Story in Big Bolts
1948 Chevy Pickup
In the DITY Gallery
One can file the skip splines to make new ones to change Pittman arm orientation with a 3- cornered file while watching a ball game or such.
ED
