2 members (55shaker, moparguy), 72 guests, and 4 robots.
Topics128,128
Posts1,056,684
Members48,452
#1248116 12/25/2017 5:40 AM
Found some.
Crusing in the Passing Lane
While you are changing tires now, it might be worth considering going to tubeless. Many tire shops will not touch split rims now, no matter what the style. What is your wheel bolt pattern? If it is 5/10 on 7.25, tubeless rims are hard to find but out there. Started with first tubeless in late '50's, look on farm trucks. 9" tires will fit on those wheels, are the most readily available size. About 36" OD.
Ed
Yeah I have 10 hole 7.50-20 's right now.
Wider tires in the front will make it harder to turn.
Jeffrey
8.25/20, is max on the front of a 4400, will work on the back though. 9.00/20 will work on front of a 6400, different axle.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
The larger tires on front of an AD truck may, or will, limit how far you can cut the wheels in a turn. The larger tires rub at back of leaf springs.
•1952 Chevrolet 3800 pickup
---All pictures---
KingG #1248419 12/27/2017 10:32 PM
That's kinda what I was thinking. I've got a good set of 8.25x20 I can use.
