| | | Forums66 Topics128,113 Posts1,056,612 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2017 Posts: 33 'Bolter | | 'Bolter Joined: Nov 2017 Posts: 33 | Found some.
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | While you are changing tires now, it might be worth considering going to tubeless. Many tire shops will not touch split rims now, no matter what the style. What is your wheel bolt pattern? If it is 5/10 on 7.25, tubeless rims are hard to find but out there. Started with first tubeless in late '50's, look on farm trucks. 9" tires will fit on those wheels, are the most readily available size. About 36" OD.
Ed
| | | | | Joined: Nov 2017 Posts: 33 'Bolter | | 'Bolter Joined: Nov 2017 Posts: 33 | Yeah I have 10 hole 7.50-20 's right now.
| | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | Wider tires in the front will make it harder to turn. Jeffrey
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | 8.25/20, is max on the front of a 4400, will work on the back though. 9.00/20 will work on front of a 6400, different axle. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | The larger tires on front of an AD truck may, or will, limit how far you can cut the wheels in a turn. The larger tires rub at back of leaf springs. | | | | | Joined: Nov 2017 Posts: 33 'Bolter | | 'Bolter Joined: Nov 2017 Posts: 33 | That's kinda what I was thinking. I've got a good set of 8.25x20 I can use. | | |
