| | | Forums66 Topics128,130 Posts1,056,720 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2013 Posts: 794 Former BMW Rider | | Former BMW Rider Joined: Dec 2013 Posts: 794 | Okay Hotrod Lincoln,
The floor is all yours.......
Thanks, | | | | | Joined: Feb 2004 Posts: 29,839 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,839 | Sorry, Andy- - - - -I've beaten this dead horse for so long there's no point in continuing. I've explained how I do it, posted pictures, and even took an almost-complete setup to the homecoming last spring, including two groove pulleys for both the balancer and a larger-diameter pulley for the pump that solves the pump overspeeding problem when using the pump conversion plate with a late-model 235 passenger car balancer and the high-mount water pump. No bites! I'm just a tired old man these days. The nice thing about beating one's head against a wall is that it feels so good when you stop. I've had enough ridicule and moderator abuse to last me several lifetimes. Jerry
| | | | | Joined: Dec 2013 Posts: 794 Former BMW Rider | | Former BMW Rider Joined: Dec 2013 Posts: 794 | No abuse intended here. I was at Homecoming last year and must have missed the discussion. I'll search the SB site and see what I can learn from your previous posts on the subject. Get some rest, we need your expertise on the Stovebolt web site! | | | | | Joined: Jun 2009 Posts: 235 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 235 | I was going to ask jerry personally about the balancer but I feel like I've bothered him so much already I was trying to not bother him anymore (at least not with something I thought would be easy).
I've never had anything but respect for him and appreciate all his help on my engine.
I'd love to know what his solution is - if you find it let me know. OR jerry, if you could pm me I'd love to hear it.
As for eBay, I must be blind, I haven't found them yet!
'53 Chevy 3604 Five Window Cab ('56 235)
| | | | | Joined: Feb 2004 Posts: 29,839 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,839 | One very simple solution is to do a little machining on a 2-groove balancer for a 250 inline six to make the pulley grooves line up correctly. I'm not too impressed by that process, as the rubber isolator between the two parts of the balancer carries the torque load of pulling the belts. My method uses a 6" diameter balancer for a 283 V8 and a 2-groove pulley for a big block V8 is installed backwards to its normal position. Some very basic machining is done to the balancer hub, same as the 250 gets. With that setup the balancer ring is free to move independently, and the pulley is driven by the 3 bolts that would usually be used to attach a puller. Jerry
| | | | | Joined: Dec 2013 Posts: 794 Former BMW Rider | | Former BMW Rider Joined: Dec 2013 Posts: 794 | Thanks, Jerry! Here's the earlier thread with pictures and supporting discussion. (CLICK) | | |
