0 members (),
97
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,128 Posts1,056,358 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 24 Junior Member | | Junior Member Joined: Feb 2007 Posts: 24 | Anyone up for a poll?
What rust removal methods do you use?? | | | | | Joined: Nov 2006 Posts: 180 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 180 | I just tried a technique that a friend found on the internet about taking rust off things like manifolds and metal parts that you dont want to blast for the potential of removing "more than the rust." Its called electrolysis and consists of running a current through water and baking soda. It takes about 48 hours and it works EXCELLENT. Instructions for it can be found online.
NOTE: PLEASE DONT GO AND TRY RUNNING CURRENT THROUGH WATER WITHOUT LOOKING FOR THE INSTRUCTIONS! haha
1950 Chevy 3100 5 window "in progress" 1967 Chevelle 300
| | | | | Joined: Jan 2005 Posts: 305 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 305 | i like a wire wheel on the grinder
ya I know a few rednecks.Thay all drive chevys to, Proud member of the Old Dominion Stovebolt Society AND A MARINE trucks range from 1942 1/2 ton to 1965 fire engine
| | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | phosphoric acid, paint prep. for small parts, just soak and scrub with a brush and rinse with water. | | | | | Joined: Dec 2006 Posts: 113 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 113 | I've been using the wire wheel on the grinder and it has worked pretty well on most items. I have heard of the baking soda and water w/ 2 amp battery charger hooked up and am going to try it but haven't yet. I was going to see if someone here had tried it first and looks like they have. | | | | | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | in the truck magazine i got last week had an article about what triple said.with pictures. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I personally have used nothing but bead/sand blasting. BUT I have been wanting to try a five gallon bucket with the Molasses concotion for small pieces. My theory has always been that if there is not enough metal to clean by blasting then get a new one....of coarse if it is available. Each piece, each person, each process is a little different requiring us to "measure twice, cut once". | | | | | Joined: Feb 2007 Posts: 24 Junior Member | | Junior Member Joined: Feb 2007 Posts: 24 | I have a car repair shop and a 1928 Case model 'L' tractor that I am currently restoring.
I started off using wire wheels, sandblasting, etc, but I found that it was rather time consuming. A friend of mine who is a chemical Engineer, gave me some of the D-Rust-It, rust remover, that you soak, spray or pump over parts. It worked so good that it freed me up to do other tasks. I have since become the Northeast Rep for the stuff, in addition to running my repair shop. Check out the link below to see if it might work as an alternative.
Lee | | | | | Joined: Aug 2006 Posts: 486 'Bolter | | 'Bolter Joined: Aug 2006 Posts: 486 | I used vinegar on some wheels and small parts. I believe it's described in the tech section on this site. I soaked overnight and pressue washed. As long as there is no paint on it, it will take it down to bare metal. You need to dry the parts and spray with rust converter asap or they will start rusting again immediately.
'64 swb stepside (gone) '57 1 ton '53 phone truck '59 swb '46 1 1/2 ton '68 swb gmc
| | | | | Joined: Feb 2007 Posts: 24 Junior Member | | Junior Member Joined: Feb 2007 Posts: 24 | It seems like soaking the parts would be the way to go. While they're soaking, you could be free to do other tasks(or relax!). I guess I'm surprised that grinding, sandblasting, and concocting/setting up molasses and electrolysis, would be so popular. Not to mention mostly labor intensive, dirty and sticky to boot. | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | sand, glass, walnut shells
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Feb 2007 Posts: 7 New Guy | | New Guy Joined: Feb 2007 Posts: 7 | Hey Lotus Boy..
I tried that rust remover from D-Rust-It a month ago. WOW.. did that work and it didnt even take off my fingernail paint wehn I reached into the bucket to take my rusty box end wrenches. It ripped the rust right off. Now I dont have to take them back to the dollar store..
Keep up the good work Sara | | | | | Joined: Feb 2007 Posts: 24 Junior Member | | Junior Member Joined: Feb 2007 Posts: 24 | Hey, Shouldn't Sara be a New Gal???
Thanks for the comments. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Has anyone tried the new stuff that is made out of BEETS? I've read about it and wouild like to "buy and try" a five gallon bucket of it but it was to expensive for my wallet. Maybe we should grow us some beets!! | | | | | Joined: Feb 2007 Posts: 7 New Guy | | New Guy Joined: Feb 2007 Posts: 7 | BEETS I thought it was BEEF. I sat a mcDonalds hamber on my hood of car and it took off the paint.. Does this count. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I've used the elecrolytic method - easy, cheap, non-toxic, and no mess I've also sandblasted, and had it done, great for scaley corrosion .... I've used phosphoric acid, perfect for light surface rust .... I've used Zero Rust , excellent product, much less of a danger than most rust conversion paints, and very durable .... and I make vinegar so I know what it can do, but there's much better uses for it there's places for nearly all methods of dealing with rust, and frequently what's cheap is what's best, including adding a bit of elbow grease Bill | | |
