1 members (DES57 ),
119
robots. Key: Admin ,
Global Mod ,
Mod
Topics128,193
Posts1,057,257
Members48,466
Most Online14,466Apr 26th, 2026
AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
over 30 years! and not clogged down with Ads! Again, thanks!
What should go here . wood on my kick panel over vent, right hand side . Did someone just put this on to reduce airflow through louvers .??? What is on your Truck On RH kick panel.??
Tom 1950 3100
Probably had the Deluxe Airflow heater mounted there at one point.
As usual looks like you guys had my answer ,, Thanks much
Tom 1950 3100
Brad, I see the heater motor opening cover has the original clutch-head screws. My heater opening covers had clutch head screws, but I do not remember if the threaded-end was like a screw or link a bolt. Am I dreaming (as usual)?
I will pull one of mine and see, I believe they are sheet metal screws.
Round heater motor cover on the firewall uses sheetmetal screws. Rectangular heater delete plate inside the cab uses 1/4"-20 threads for a bolt.
"I always win." Working mainly alone I do not let my trucks win a war. Maybe a battle here and there but never the war. Robert 55.1 GMC 450 COE 51ish GMC Suburban
