1 members (papas52), 111 guests, and 4 robots.
Topics128,193
Posts1,057,253
Members48,466
What should go here . wood on my kick panel over vent, right hand side . Did someone just put this on to reduce airflow through louvers .??? What is on your Truck On RH kick panel.??
Tom
1950 3100
V
V Offline
Probably had the Deluxe Airflow heater mounted there at one point.
As usual looks like you guys had my answer ,, Thanks much
Tom
1950 3100
These are what the original set looks like, a bit different than the reproductions. There is also a gasket that is used with the heater install but not the block-off plate (I have seen a couple with it, but not all)?
https://www.flickr.com/photos/advance-design_parts_co/15838946822/in/album-72157631868452754/
https://www.flickr.com/photos/advance-design_parts_co/8129439572/in/album-72157631868452754/
Brad,
I see the heater motor opening cover has the original clutch-head screws. My heater opening covers had clutch head screws, but I do not remember if the threaded-end was like a screw or link a bolt. Am I dreaming (as usual)?
I will pull one of mine and see, I believe they are sheet metal screws.
Y
Y Offline
Round heater motor cover on the firewall uses sheetmetal screws.
Rectangular heater delete plate inside the cab uses 1/4"-20 threads for a bolt.
"I always win." Working mainly alone I do not let my trucks win a war. Maybe a battle here and there but never the war.
Robert
55.1 GMC 450 COE
51ish GMC Suburban
