Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
0 members (), 137 guests, and 4 robots.
Topics128,283
Posts1,058,506
Members48,490
#865401 07/09/2012 1:14 AM
They may be replacement blades (are there any codes/numbers on the blades)? I bought a generic 6-blade fan blade in the middle 70s (NAPA).
One 6-blade unit is listed up through 1957.
i didnt see any numbers on them ill look again . one blade came off a 216 engine in a 36 flatbed
What is the diameter of the center hole in both fans?
My Blog
they are 1" they fit my 54 water pump perfect
Than it looks like you have two of the "3707662 18inch low speed 1937-55 1st truck" fans.
My Blog
they are both 18" blades . what does low speed mean ? are they better than the 4 blade fans ?
I believe they were intended for trucks that would be going slow in the fields, like grain trucks.
My Blog
Six blade fans were also used on some of the 216s used to power Canadian army trucks. I'm not 100% sure of their reasoning but added cooling for desert warfare would make sense to me.
I have a 39 with a 216 engine. On a hot day it would overheat with the 4 bladed fan. I was given a 6 bladed fan. Now it will idle all day long without overheating. A big difference.
1939 Chevrolet Stake Truck
That's what it says for the 1937-1955 6-blade fan listed in the 1929-57 Master Parts & Accessories Catalog (at the link above): low speed operation, 6-blade, 18" diameter (3707662 became available in 1954 and replaced the earlier 6-blade fan 604225).
I just saw an ad on ebay for a used 6 bladed fan 37-46 for $100.
back yard wrench turner
I used the 6 blade off of the 216 I removed. It moves air like a hurricane.
fan
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
I know this post is 5-1/2 years old, but I'm looking for one of these 18" 6-bladed fans for my 37 Chev firetruck.
Bryan
Beaverton, OR
2 Offline
I am looking for one as well, for my 1951 Chevy grain truck. She gets hot really easy moving around the farm and in the field.
1951 Chevrolet 6400
Crusing in the Passing Lane
Might want to make a shroud with a hole in it for the fan, so air is pulled through all the radiator, not just the part in front of the fan. Use a flat piece of Al, secured on the edges to the radiator frame. Fan should be partly through shroud. Get some flexible rubber mat pieces to make flaps so at speed the air can go right through the flaps-look at VW Rabbit, etc.
Ed
I will check a friends garage (his dad was old school engine builder/gear head). There was 3 or 4 - 6 blade fans in the corner. Also has 3 235’s, 10 265’s, 7 power glides, two complete drive trains for 54 or 55 210’s and a ton of other stuff we are sorting through.
The fans just might be the 6 blades from I 6 or from 265/283 v8s
Are there a difference?
1954 Std Cab 3100 w/ 2 spare Engines
IL
1954 three window 3100
Check OD of blades, mounting bolt pattern and ID of shaft hole.
Ed
Found the fans; they were 4 blades. Will dig deeper the next time there as we aware we saw some 6 blade fans.
Ed, Thanks for info on identification
IL
Insomniac
Insomniac
Interesting. Why not aftermarket?
Flex-a-lite
Gord 🇨🇦
1954 1/2 ton 235 4 speed
I have one of those Flex-a-lite nylon fans on my 55 210. They sure move a lot of air.
Brian
1955.2 3100 Truck
