2 members (latroca52, 1 invisible),
131
Mod | | | Forums66 Topics128,196 Posts1,057,388 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2017 Posts: 8 New Guy | | New Guy Joined: Mar 2017 Posts: 8 | I've got a 1954 pickup with a 235, original carb & distributor. Carb has been cleaned, choke working, new plugs, points set, still 6 volt coil, timing set well in advance of top dead center, compression good in all cyl.vacuum advance seems to work Still cannot get it to run right. It idles OK when warm, poorly when cold. High RPM is also OK, mid range very poor, seems to be cutting out.
I'd like to pay someone in the Dallas area that knows these trucks to go over it and see what's wrong.
Any recommendations?
Thanks much. I'm at the limit of my expertise here. | | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | check for vacuum leaks first.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Dec 2005 Posts: 547 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 547 | timing set well in advance of top dead center That might be part of the problem, depending how far in advance it is. Also, do what SWEET said, check for vacuum leaks. What part of Dallas are you in? I'm close to the White Rock Lake area.
58' 3200 235 3-speed/OD
| | | | | Joined: Sep 2010 Posts: 2,337 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,337 | Check the points the set I got for mine had two pieces in the box spring was separate .it would idle okay but would miss and backfire when the throttle was pushed .turned out the extra spring piece if not put on would make the points jump around when the throttle was pushed . | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Gary,
"timing set well in advance of top dead center"
What is the setting and how did you set it?
| | | | | Joined: Apr 2017 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2017 Posts: 47 | I live in NW Dallas County. And, I'd love to know about anyone that works on ADs. There's just some things better left to others.
1955 Chevy (1st Series) 3600
| | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | Make sure you’re burning fresh gas. Old ethanol laced gasoline won’t run wort a darn no matter how good you’ve tuned it up!!! I know from experience.
Chuck 1950 Chevy 1/2 ton (all original) 1951 Chevy 1/2 ton (future streetrod) 1941 Chevy coupe 1938 Chevy coupe streetrod | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Ok Texas Connection, help your fellow Texan out. The OP said he wants to pay someone. He is at his limit of mechanical knowledge. So far nobody has posted the name/location of a shop to help the guy. Y’all are better than this, give the guy a hand.ðŸ›
| | | | | Joined: Apr 2017 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2017 Posts: 47 | Yes, please. Share contact info. I need brakes & front end work. And I'd like to have it done by a professional that will warranty the work. My old hands and back just don't work as well as they used to.
I've talked to a couple of shops. But, they like to charge higher rates for "vintage & classic" vehicles, as if they're harder to fix. One guy quoted me $2500 + parts to do a brake job.
Please post info on any/all DFW area mechanics who will work on ADs & other classics (I have a 66 Impala, too). Gonna need the motor rebuilt, someday.
| | | | | Joined: Mar 2017 Posts: 8 New Guy | | New Guy Joined: Mar 2017 Posts: 8 | I might have found at least one problem - the former owner has suppression spark wires in there. Will check on vacuum soon, get some ethanol free gas and re-check the points. Appreciate your input. | | | | | Joined: Nov 2001 Posts: 438 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 438 | Gary Tx I have friend who does restorAtion and mechanical work on older vehicles. I'll ask him if he wants to look at it. Call Sid @ 214-213-2471 if you still need help.
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
| | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | I'm not in DFW area, but if willing to go 90 miles west of Ft Worth be glad to help you out. I'm in a small town called Ranger, TX and I work on the older vehicles. | | | | | Joined: Dec 2005 Posts: 547 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 547 | Give Donny a call at Compton Automotive. I have known him for years and they do have the occasional classic in his shop. He has a Corvair in there now. I would call and ask him about what you need done and he will be honest with you about what he thinks would be the best course of action. Link to the webpage: Compton Automotive
| | | | | Joined: Apr 2017 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2017 Posts: 47 | Does anyone have any experience (good, bad or indifferent) with Wilson Auto Repair, in Garland, or Trowell & Turner Automotive, in Dallas?
