Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
1 members (Shade Baby), 21 guests, and 4 robots.
Topics128,009
Posts1,055,293
Members48,419
#124702 02/26/2007 3:20 AM
I'm working on a 66 Chevy pickup and will be doing some body work, but will be driving the truck. So, show quality is not necessary, but I do want the paint to adhere, etc. If I have a panel stripped and then apply epoxy primer, sand the spots that require filler, apply body filler...then what? Do I coat that spot with epoxy again before applying a filler primer?
#124703 02/26/2007 3:40 AM
That is the way my buddy the bodyman does it,,Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#124704 02/26/2007 3:58 AM
SixPac,
I'm just a amateur...the epoxy, or 2-k primer I use Is a filler primer. It is very heavy bodied.
They make a sprayable "Bondo", but your non-show quality truck certainly wouldn't require this item.
The sequence would be...bare metal coated with etch primer, and this is truly optional..then coated with 2-k primer. This coat is lightly abraded and body work and any Bondo work is done.
A final coat of 2-k primer, either to spot cover the filler, or re-coat the item for added sanding, then your final color.
Stuart
#124705 02/26/2007 5:03 AM
Just to add.......in case you didnt know....primer doesn't protect from rust. Its actually very porous,,it acts like a sponge.
Lots of people think theyll sand their truck down and prime it and drive it for a couple years,,,,it'll start rusting before you know it.
Marty
#124706 02/26/2007 5:07 AM
Marty,
I'm pretty sure the 2-k primer is impervious to just about anything. This is the stuff you see on rigs that are just primered and run around the streets forever...even through the car wash.
Stuart
#124707 03/10/2007 12:50 AM
Ok, What other experiences & opinions are there concerning driving around a for a year or two with just 2-k primer? I think some of the black hot rods seen are actually a flat Old school type modern top coat and not primer.
Eric
http://s1199.photobucket.com/user/sparky234/library/My%2057%20Chevy%20Stepside?sort=3&page=1
'57 Chevy 3100 (Little Red)
'81 RD350 LC - Fun, Fun, Fun
'83 GS1100E - Pocket Rocket
#124708 03/10/2007 1:56 AM
no doubt some of the rods use a flattened finish coat, but epoxy primers [2 part, high build or thin build] are definitely waterproof and can be used for top coats - my 58 did fine for a couple years with the front epoxy primered until all the body work was ready for paint - and epoxy primer can be tinted to some extent
the primer-surfacers, etching primers, and the usual lacquer rattle can primers aren't waterproof
#124709 03/10/2007 6:08 AM
Must be the new generation bodyshops nowadays,
but the only fillers applied to a body was on bare
metal only...At GM every product on the market We
had and used daily, plus using experimental products, materials that never was introduced to the market because of being so toxic...I am sure that the 2K primers would be waterproof, being a urethane
based primer...The flat looking black cars, they
painted with flattening compound in the paint that
kills the gloss...Was popular on street rods...
Bill B
1952 Chevy 3104 Shortbed 5-window
Remember; Politicians and diapers both need to be changed
often, and for the same reason.....
