1 members (Naturalthud), 110 guests, and 3 robots.
Topics128,135
Posts1,056,423
Members48,441
My 1954 has the original engine, but no oil filter, why not? Does it need one? I guess after 85,000 miles it must not. Any reason they did not factory intasll a oil filter?
Also I am thinking of putting in a electronic ignition, any idea's on that idea?
Thanks Rick, This truck is new to me, and I have always had, MGA's, or 356 Porsche's so I am just learning how this truck works
Rick, Rusty, Lerma, MGA's, and a 1954 Chevy 3100.
An oil filter was not standard equipment.
1qt and 2qt by-pass oil filters were available as RPO (Regular Production Option) in the original purchase or as an after delivery accessory, installed by the owner, dealer, friend, shop, etc.
Electronic Ignition is not needed. Just keep the present point/condenser/rotor maintained and life will be much simpler. Having said that, there is the “Cool” factor of a big honking GM style HEI hung on the side of the I-6. JMO🛠
One of the reasons is cost, let's say GM calculated $5 per filter set-up, production is 250,000+ units a year. Adds up fast in a very competitive market. They would have known the return potential and most likely made out better with dealer supported accessory supply.
I also would not bother to install electronic ign, unless I was going to highly modify the whole rig.
Craig
After installing a 6v Pertronix unit (for no good reason - it looked interesting), I agree with cmayna.
In either case (points/Pertronix), on long trips I carry a completely-tested distributor "assembly" (including ignition/plug cables). I have never needed to use this, but it is a good "insurance policy".
An HEI allows a larger plug gap and a slightly colder plug than the original, it may be worth some gas mileage.
Tim, Brad, and fellow 'Bolters -
Rick is the new owner of my '54 3104. The truck couldn't have gone to a more appreciative owner of classic original vehicles. Glad to see that he has discovered Stovebolt and your combined knowledge. I agree that points and condenser serves these old trucks just fine.
- Lonnie
- Lonnie
My '54 3104
Hello, Lonnie,
Thanks for the post.
I think that Rick would have had a hard time finding a nicer vehicle.
I agree, I had been looking (low key) for over 8 years for this truck! I could not have found a better one! Thanks Lonnie for keeping it such original great condition!
The moment I spotted it, I knew I had found it.
2 Dist. are a good idea, that way I can test the electronic ing. against the orig. one. I found on my MGA's that the electronic's dist. is better, It gives a hotter spark, easier starting and more reliable. and have a backup on long trips. After I installed it in the MGA it ran better and started eaiser. But maybe the careful timing I did with it was why?
Rick
Moderated
Moderated
Just an update...Lonnie had it, Ric bought it in 2017, later gave it to his son to sell in Colorado. Saw it on the internets in 2018 and bought it in October. Now I own it! In great condition for a '54! Added the oil filter canister to the engine, new clutch, fixed all the leaks, added the optional dashboard clock, radiator overflow canister, re-chromed the front bumper and added the running board non-slip treads (an honest to G_d dealer option!) It is still in stock style, runs great, lots of fun to take to the meet-ups.
Welcome! Many thanks for the update.
Mike
Hey "54GreenMachine" -
I occasionally return to Stovebolt (best forum on the net) to see what's up with old truck. I found your post. from two years ago.
I hope that you love the truck as much as Jo Ann and I did.
Looks like you've only made one post. If you see this, then you gotta post a pic of you, your wife, and the dogs in your Christmas card. PERFECT!
- Lonnie
- Lonnie
My '54 3104
