3 members (Hotrod Lincoln, 1955 1 Series, tricordati), 157 guests, and 5 robots.
Topics128,095
Posts1,056,480
Members48,444
Well, thanks for all the excellent help & advice,
because of it....I've decided to do a full overhaul.
Originally, this engine was a PowerGlide with Hydraulics, ('53 235 FP)
at some point it was changed over to "Stick" trans and Solid lifters, cam & pushrods.
I'm staying with the Stick.
My question is what's the "Pros & Con" of new Hydraulics -vs- Solids?
What should I go with?
Thanks, Jim
Subscribing to this one as that'll be one of our first mods.
1953 Canadian GMC 9314 w/ (factory) Chevy 235
I thought that there were absolutely no new hydraulic lifters available for our engines?
~ Dave
Let's hear from pros on these questions, Jim
If you are sure your engine's cam was changed to a mechanical lifter cam, or not, and you are going to replace the cam, I'd go with the mechanical lifter set-up (all cam/lifter/rocker-arm parts).
It looks like hydraulic lifters are available?
