Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
6 members (Phak1, Otto Skorzeny, Frank50, Crimson48, 55shaker, JW51), 63 guests, and 0 robots.
Topics128,007
Posts1,055,275
Members48,418
I have a 235 engine that I was told came out of a 1958 Chevy when they were making it into a
hot rod.
Numbers on the block are:
6 307
CON 3
L 47
3738307 - From this number I found out 235 from 1958 to 1962
F207B behind the distributor
On the head:
B 38
B 46
CON 12
850
848
I hope you bolters can help to pin point what I have.
Thanks, Jeffrey
Jeffrey,
Here are locations and names for various casting codes.
L 4 7 looks like a block date casting code - check the location at the link above.
L = 12 = December
4 = 4th
7 = 1947
F 207 B
Flint, Michigan assembly plant
2 = February
07 = 7th
B = 235 car engine with Powerglide transmission (it would have had hydraulic lifters)
Those head codes are not the pertinent codes for identification.
Perhaps it is a very late 1947 engine that had been installed in an early 1958 vehicle?
Tim thanks for the response.
Along with the 3738307 indicating a 1958 - 1962 on another website.
They also discussed that the L 47 could also be that it is December 4, 1957.
Thus an early 1958 car engine.
You are right about the powerglide because the engine still has the automatic
flex plate. I did not take off the side cover to see if the engine has hydraulic
lifters. Though the rocker arms still have the lock nut and threaded screw to
adjust the valve lash.
The engine also has a 12 volt ignition coil and a 2 stage fuel pump. Meaning
vacuum boost for the wipers.
