1 members (NJC),
62
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2013 Posts: 148 Shop Shark | | Shop Shark Joined: Jun 2013 Posts: 148 | I have 1954 3600. I have searched this for a long time. Does anyone know what might be fit in the doors where the the small bumpers fit? I can't find any part numbers. I hate to start buying different switches just to find that they wont fit or might be too long. I know someone might remember what they used. Thanks Sharon | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Dome lite switch part numbers 1954 3600 Does anyone know what might be fit in the doors where the the small bumpers fit? I can't find any part numbers. I know someone might remember what they used.
Sharon,
I am most likely confused, but, are you looking for? There was no original dome light switch in the doors. The only switch was up on/in the dome light housing. | | | | | Joined: Jun 2013 Posts: 148 Shop Shark | | Shop Shark Joined: Jun 2013 Posts: 148 | I want to put a switch on the door jam so the lite works when you open the door. Like most other cars do now. Sharon | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | What they used: nothing was available for 47-55 trucks - "in the day".
The original light/lamp switch provided a ground to the bulb. The lead/wire to the housing is always hot to the "normally" ungrounded bulb. A ground (turn/flick the switch on) is needed for the bulb to light.
When other cars/trucks had/have a switch, it was a spring-loaded button in the door jamb, providing an on/off switch to the lamp housing.
To make that work with your original housing, you could run a ground-lead from each door and connect both door leads (from each/both side/door) to the switch in the dome light housing.
Let's hope someone will correct/chastise me, and will provide an easier "solution". | | | | | Joined: Jun 2013 Posts: 148 Shop Shark | | Shop Shark Joined: Jun 2013 Posts: 148 | I understand the wiring of the switch, I just need a little help in finding what door switch may have been used by the Stovebolt members Sharon | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I join you in my interest in what others might have set up for an "automatic" switch. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Back in the late 50's early 60's I was a parts man at a Chevy dealership. The cars all had normally on, push button door switches as Tim described. I installed many 'accessory' under dash lighting kits in my own Chevy's and for others. Obviously you won't be able to find any of those original accessory kits today, that would be like striking gold I'm sure. Brad Allan now doubt has an example of these in his museum, maybe he can chime in and show us a picture of one. And I'm sure you have accessory books Tim, that list the under dash kits, no?? But.....if it's just lighting that you're interested in Sharon, there are many under dash/footwell LED lighting kits on the market now a days for around $15-$20. All the ones I've seen from a brief tour of the internet, are for late model cars which already have footwell lighting. So, you would have to get creative and purchase push button switches such as available on Amazon then find a good spot to drill a hole. You seem to understand the electrical part of it, that would simply be running a hot lead to/thru the switches and and out to the lights and grounding the circuit. Let us know what you come up with. Denny Graham Sandwich, IL .
Denny G Sandwich, IL
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | You are looking for a standard momentary, normally on, push button, bulkhead mount, switch. Something like this. As seen in TC's link pix...or these.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jun 2013 Posts: 148 Shop Shark | | Shop Shark Joined: Jun 2013 Posts: 148 | That's what I'm talking about guys, thank you for all your input. Now to order parts and fish wires down to doors.
Thanks again Sharon | | |
