| | | Forums66 Topics128,075 Posts1,055,918 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | I came across a '41-46 GMC speedometer to use in my '40 Chev. However, the cable connection is much larger. This is about 7/8" diameter, my Chevy is much smaller, more like 5/8. Is the larger size normal for the GMC pickups? The one I got is supposedly for the big CCKW trucks. Might it be specific to those? I'm guessing I can have a cable made up but I need to better identify what the connection at the speedometer is.
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | HI Dennis,
The GMC speedometer head connector is larger than the Chevy. Perhaps you could change to a GMC speedometer cable? Not sure about the transmission side.
Odd how some GM family parts fit while others don't...
Paul
| | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | That's a good idea Paul. I'll order one up and see. Thanks.
Dennis
40 Chevy 1/2 ton
