Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (SandraD, baldeagle, farmallb, Peggy M), 51 guests, and 1 robot.
Topics128,005
Posts1,055,261
Members48,418
#1245918 12/06/2017 2:20 AM
I have my casting number ID'd as a 235/250 62 through ? my ID # appears to be FO 05TA does this appear to be correct its a 1963 C10,, any help please,, Thanks
I have a 55 second gen!,, work in progress
1963 long bed step side driver
Just a guy who digs old trucks!
I couldn't find an exact breakdown of the code you have posted, but I did find a "TA" code that was used for the '65 230 and the '66-'68 250 used in 2wd C10 trucks with manual transmission. It seems that your code is missing one character, as it should have letter for the plant code (F is usually Flint) then a Month/Day code, and lastly, the application code. You might check for a casting date somewhere on the block or head. I can't really give you an exact location on that generation of Chevrolet 6, as my knowledge is more with the earlier 216/235/261, but you might look somewhere near the starter.
Bill Burmeister
235 and 250 used different block castings. 230 and 250 used the same casting and we're first installed in 1963. 1962 was the last year for the 235 in these trucks.
Thanks I will try to get a better block ID number as its pretty rough
62Stick #1245968 12/06/2017 2:05 PM
Thanks The casting number is 3877178, What I found is it could be either?
Take a plug out and look in the cylinder, if the piston has a flat top it's a 230, if the piston is dished it's a 250.
Tommy
59 apache 1/2t
261 short stepside
307 V8 pistons are a drop-in fit in 250 engines, and they're flat tops.
BoToepfer #1246104 12/07/2017 11:06 PM
question on 307 pistons in 250 engine what do i end up with comp. hp any idea
BoToepfer #1246105 12/07/2017 11:12 PM
i put one in my 51 3100 along with a 5 speed trans from a s 10 annd a camaro rear end and love it im thinking either doul carbs or small 4 bl and split eh manufold... and i like the flat top piston idea
