1 members (Materman),
107
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2017 Posts: 370 Shop Shark | | Shop Shark Joined: Jun 2017 Posts: 370 | When you make a non flared connections, such as threaded. Is there anything I should use on the threads to aid in sealing? I’m putting a glass bowl filter in front of the carb.
Thx Don
Can’t begin to tell you how much I hate the name Stovebolt.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Don, I've never used anything and had no problem. Others may have? I will say I've had some problems from previous owners ruining the connection due to tightening the living daylights out of them. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Permatex #2 is what I use.
Or there is a blue pipe sealer goop intended for gasoline, not the white stuff. | | | | | Joined: Jan 2014 Posts: 3,683 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,683 | Nothing is needed. You can more harm than good using something that isn’t fuel resistant.
1951 3100
| | | | | Joined: Jun 2017 Posts: 370 Shop Shark | | Shop Shark Joined: Jun 2017 Posts: 370 | Thanks for the advise guys. I think I will try using nothing first and then go with something gas proof if needed. Unfortunately I’m using a rebuilt carb and it may have had the connection over tightened. Which was the case before.
Going with a new tank and lines too.🤗
Thx Don
| | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | My favorite non-hardening sealer is Permatex Super 300. (Not 3-D) It was developed to seal aviation gasoline fittings, so it's definitely useful on pipe thread fittings for fuel pumps, gas tanks, etc. Flare fittings do not need any sort of sealer, as the threads of the nut don't do any sealing- - - -the angle of the tubing flare and the part of the fitting it meets seals the liquid.
| | | | | Joined: Jun 2017 Posts: 370 Shop Shark | | Shop Shark Joined: Jun 2017 Posts: 370 | Nothing at first worked fine until I went for a good spin. The threaded connection at the carb had a very slow drip and the flared connection I made was dripping. I used Teflon on the connection to allow me to get the nut tighter.
The connection at the carb was “loose” due to previous owners over tightening because the nipple bottomed out before the threads got tight. I used some thick high quality Teflon on that.
I looked at a lot of carb pictures on the net and almost all of them had signs of gas leaking in that location. Even the trailer queens.
Thx Don
| | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | By Teflon, I hope that you are referring to something other than tape. Teflon tape has a nasty habit of disintegrating in the presence of gas, and then gets inside of the carburetor into places where you cannot easily get to without removing casting plugs. Carl
| | | | | Joined: Oct 2016 Posts: 916 'Bolter | | 'Bolter Joined: Oct 2016 Posts: 916 | Don, are you talking about a compression fitting or a flare fitting?
~ Dave 1950 Chevrolet 3600 3/4-ton with 261 engine & T5 Transmission | | | | | Joined: Feb 2016 Posts: 1,987 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,987 | I had to use Teflon tape on the pipe threads due to worn threads, just keep the tape back from the first three or so threads, if your using anything on flare or compression fittings that means the flare or compression fittings need to be re-made.
| | | | | Joined: Jun 2017 Posts: 370 Shop Shark | | Shop Shark Joined: Jun 2017 Posts: 370 | The Teflon is back far enough to keep from getting in the carb. The flare may not have been big enough. The nut isn’t the best quality and I don’t have a tubing wrench. So the Teflon did what it is supposed to do, allowed the nut to tighten properly. And when I need to remove it it will loosen without destroying it.
Had a nice trip across the river into town today. Hard to believe it could run any better. Now I need to find new gears for the rear end so I can keep up with the 50 mile an hour gang.
Don
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 |
| | | | | Joined: Jun 2017 Posts: 370 Shop Shark | | Shop Shark Joined: Jun 2017 Posts: 370 | I looked at countless pictures of the exact method I used. Many use Teflon to get the nut tighter. Don
| | | | | Joined: Jul 2000 Posts: 2,191 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,191 | Your wife is probably looking for a hint as to what to get you for Christmas. If I didn't have a set already, a set of flare nut wrenches would be good...
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Jun 2017 Posts: 370 Shop Shark | | Shop Shark Joined: Jun 2017 Posts: 370 | Your wife is probably looking for a hint as to what to get you for Christmas. If I didn't have a set already, a set of flare nut wrenches would be good... Thankfully my truck only requires 2 sizes. Don
