Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (WingWright, baldeagle, NJC), 42 guests, and 3 robots.
Topics128,004
Posts1,055,246
Members48,418
#124549 02/13/2007 3:06 AM
I just had my rims soda blasted today and the guy told me to wash the rims with water and some vinegar to dissolve any soda remaining in tight areas. I did so and am having a problem with flash rust. Should I have washed the rims or was that a mistake? I was planning on using Eastwoods Rust Converter, but should I worry about the light rust or is it ok with a converter?
thanks. Michael
#124550 02/13/2007 4:22 AM
i wash with phospheric acid after i blast,however i'm not sure i would use that on wheels.having said that, a light wash should not cause the metal to become brittle like it may if you were to soak them for while.
the rust converter is not much different. wire wheel or brush the flash rust off and prime then you should ready for what ever finish you choose to use
tom
I don't suffer from insanity, I enjoy every minute of it!
#124551 02/14/2007 5:14 AM
Junior Member
Junior Member
1 Offline
Napa auto Parts used to sell some stuff I think called "primeze" or "cleansease" I cant remember. but it is a liquid that wipes off that new "overnight" rust.
"It ain't the years that hurt, its the mileage"
#124552 02/21/2007 7:24 AM
Spray them with ZeroRust - right over the fash rust. Prime and paint with whatever paint you want ... that's exactly where ZeroRust work best.
