| | | Forums66 Topics128,005 Posts1,055,264 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | I just had my rims soda blasted today and the guy told me to wash the rims with water and some vinegar to dissolve any soda remaining in tight areas. I did so and am having a problem with flash rust. Should I have washed the rims or was that a mistake? I was planning on using Eastwoods Rust Converter, but should I worry about the light rust or is it ok with a converter?
thanks. Michael | | | | | Joined: Mar 2005 Posts: 267 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 267 | i wash with phospheric acid after i blast,however i'm not sure i would use that on wheels.having said that, a light wash should not cause the metal to become brittle like it may if you were to soak them for while. the rust converter is not much different. wire wheel or brush the flash rust off and prime then you should ready for what ever finish you choose to use tom
I don't suffer from insanity, I enjoy every minute of it!
| | | | | Joined: Feb 2007 Posts: 13 Junior Member | | Junior Member Joined: Feb 2007 Posts: 13 | Napa auto Parts used to sell some stuff I think called "primeze" or "cleansease" I cant remember. but it is a liquid that wipes off that new "overnight" rust.
"It ain't the years that hurt, its the mileage"
| | | | | Joined: Feb 2000 Posts: 203 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 203 | Spray them with ZeroRust - right over the fash rust. Prime and paint with whatever paint you want ... that's exactly where ZeroRust work best. | | |
