3 members (Donf, Oswald, Bill Hanlon), 133 guests, and 1 robot.
Topics128,042
Posts1,055,519
Members48,424
#1245476 12/02/2017 9:44 PM
sly
Offline
I have a 55 1st series 1 ton with the original 235 that needs a new water pump. All the parts houses and even Classic Pats show something that looks nothing like the original and it has a plate on the back so the impeller does not even enter the block. Has anybody seen one of these or know if it’s new design, and will it actually fit my truck?
sly #1245477 12/02/2017 9:48 PM
sly,
That style water pump is correct for a 1955 1st series (and, earlier) 235/261.
What is the Engine Serial Number on your engine (pressed into the block to the rear of the distributor)?
sly #1245479 12/02/2017 10:00 PM
sly
Offline
Looks like K 11 5
sly #1245484 12/02/2017 10:55 PM
Sorry, sly, that does not match GM docs that I have.
K 11 5 looks like a date casting code:
K = 11 = November
11 = 11th
5 = 1955
A date casting code appropriate for a 1955 second series and later 235.
Can you take a photo and attach/post it here? The engine serial number is pressed/stamped into the block in the smooth/machined "ledge" behind the distributor, where the enter the block.
http://www.1954advance-design.com/Web%20images/casting-code-photos/codes-ser-nums.html
sly #1245487 12/02/2017 11:49 PM
Offline
Offline
$150 plus shipping to rebuild your pump. Upgraded seal, 3 year unlimited mile warranty.
PM sent
My 1955 GMC 450 Dump Truck
Elderly Iron
"Performance" is the pursuit of a toy that won't break.
sly #1245493 12/03/2017 1:06 AM
Rely on the PM and/or email - no need to do private notification in public.
sly #1245882 12/05/2017 9:37 PM
Sounds like its got a later engine, 55.2 & up.
BC
1960 C60 pasture art
Moderated by  Dusty53
