Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
6 members (walter74, Bill Hanlon, 68ironhead, JW51, Greg_H, Peggy M), 63 guests, and 2 robots.
Topics128,009
Posts1,055,296
Members48,419
#1245311 11/30/2017 10:10 PM
So, thanks to all, Im well on my way on the front suspension of my chevy 1950 3100 . I'm actually using a chevy Colorado front suspension
on my danford crossmember. Better brakes, and I got it cheap.
so, anyway, trying to figure out rear suspension. I'm not Mr. moneybags , but not Mr. cheapo either
So, I'm asking for opinions on this idea. Rear axle out of a 4wd s10. ( u guessed it, I got it cheap!) Use stock rear springs form the 3100 , but only use 2 or 3 leafs , then use air shocks
such as Monroe or Gabriel. Or maybe air bags.
I'm worried about getting done and not having the thing sit level . Also like the TCI rear leaf suspension, but it mite sit a little lower than I want.
I want to lower front about 2 inches then the rear 3 inches.
Don't want to worry about hitting road kill, but but want it lower than stock.
Opinions, thoughts, or great wisdom appreciated! thanks ,charles
I just finished a 1946 chevy pickup street rod
now on a 1950 chevy 3100
also a GMC 220 with duals
and a 1948 chevy 2 ton
Charles Pretzer #1245320 11/30/2017 11:33 PM
You asked for opinions, thoughts or great wisdom. I almost always have opinions, occasionally have thoughts, but rarely have great wisdom. So, here are my opinions, some of which reflect my experiences building lowered C10s in my younger days.
I have never had good results using air shocks. Air bags would be a better option in my opinion. Removing too many leaves from the spring pack may lead to "axle wrap" under hard acceleration, if not compensated for by other means; i.e.. traction bars or the like. I always liked the simple method of lowering the rear; raise the axle above the spring pack. However, that may give more drop than you want.
Oldbolter
1959 Apache 3800 dually flat bed/dump with 261
1956 3800 dually flat bed/dump with 235
1957 3600 flat bed, 350 engine, 700R4, PS, disc brakes, 14 bolt rear with 4.11 gears
Air bags will take more work to install but will make for a much nicer ride than air shocks.
The axle on a '50 1/2 ton already sits above the springs.
I'm using a set of 3 1/2" spacer blocks from Sid Drappel on the back of my '53. That's an easy mod that still allows you to haul a load.
