| | | Forums66 Topics128,015 Posts1,055,335 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | The neighbor had this disc laying buried in the mud in the field out behind his house for a few years. Under the mud, It was covered with concrete. To him it was just a piece of scrap he'd picked up on a job somewhere, to me.....a sow's ear to be turned into a silk purse. After chipping the concrete off I found a 2" thick by 24" disc that appears to be a steel casting. It rings like steel, doesn't have that familiar thud that cast iron typically has. when hit with a hammer. The dang thing weighs 260# and I've been trying to think of some use for it. Well...I'm modifying and motorizing a 1/2" plate bead rollers that I made way back when I built my Pitts special biplane. So.....I think I'll use it for a base for the roller and I've had a chunk of 8" main line for natural gas standing in the corner for a couple of years that I guess I'll use for the column. Over Kill??? By a bunch for sure, but I might as well put these old scrap pieces to good use. That'll be one ell of a solid stand for that bead roller. http://www.pbase.com/dennygraham/image/166647667/large Denny Graham Sandwich, IL .
Denny G Sandwich, IL
| | | | | Joined: Aug 2003 Posts: 106 Shop Shark | | Shop Shark Joined: Aug 2003 Posts: 106 | What a waste. You should machine that into a hubcap press for straightening old hubcaps. So sad.
"I always win." Working mainly alone I do not let my trucks win a war. Maybe a battle here and there but never the war.
Robert 55.1 GMC 450 COE 51ish GMC Suburban | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | The thought of machining it did cross my mind Sonora.......but it won't fit in my old 16" Lodge & Shipley. It's gonna be WAY more base than I need to steady up a bead roller but.....I've got it, so I may as well use it. Gonna be a SOB to move around and I like to keep my tools mobil whenever possible. Thought about investing in some good strong locking casters. When finished the whole rig with a full set of dies could weigh upwards of 450-500 pounds. Mostly cuz of the stand it's sitting on. dg
| | | | | Joined: Aug 2001 Posts: 3,587 Moderator | | Moderator Joined: Aug 2001 Posts: 3,587 | Looks like a plate of rolled steel, torch cut to the Dia. that it is now. Overkill? Maybe, but build it the way you want to. Keep posting with pictures and let us know how it turns out.
Don
Edit: Nice box in the background!
1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Thought it was a rough cast iron something from the local foundry Don. When I first saw the thing it had about 2" of rough concrete covering the whole thing, like it had been broken out of a slab. The more I chipped the better it started to look. No....it's not a flame cut piece of plate, cuz it's got a four or five inch hub about an inch tall cast into one side. I gotta do some more testing to see what it's made of, but a quick spark test and smack with a ball peen makes me think it cast steel, and it dents like steel also. I think it may have been a blank for a flywheel of some sort. Around the turn of the century Sandwich Manufacturing was a big player in the farm equipment business. They made the Sandwich hit 'n miss engines, hay and grain handling farm equipment, of which, the Sandwich engines were one of the best in the country. I suspect this could be something that was left over when they closed down the factories and somehow it got caught up in a concrete foundation or patio. My neighbor does demolition and that's how he found it. dg
| | | | | Joined: Aug 2001 Posts: 3,587 Moderator | | Moderator Joined: Aug 2001 Posts: 3,587 | Sounds like you are right then Denny. I learn something from every one of your posts.
Don 1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Looks like a hernia waiting to happen!
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Got that right Marty, every time I've moved it, I gotta be real careful to keep it in balance. Once it starts to go I just get the ell out of its way. Then go looking for the Johnson bar to pry the edge up.
And Don, I've learned a lot about old anvils from your passion for them. dg
| | | | | Joined: Dec 2002 Posts: 3,437 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,437 | I like finding stuff like that, I rarely bring it home though, Mrs. Rod says I have too much "junk" laying around. I would use it to mount my fathers old 100 lbs anvil to, sure glad I was able to save it from him selling it for $20 like the other three he had.
| | | | | Joined: Sep 2013 Posts: 1,361 'Bolter | | 'Bolter Joined: Sep 2013 Posts: 1,361 | Rusty Rod said; "I like finding stuff like that, I rarely bring it home though, Mrs. Rod says I have too much "junk" laying around."
My response to Mrs. Moparguy for that particular argument "It's not junk, it's precious metal". Don't say it out loud too often though.
RonR
1951 3600 with Clark flatbed, T5, 4.10 rear 1970 340 Duster 1990 5.0 V8 Miata (1990 Mustang Gt Drivetrain) 1964 CJ5
