10 members (dt235sd, Phak1, Rusty Rod, Gdads51, Bill Hanlon, 68ironhead, GMCJammer51, 3B, KEVINSKI, 1 invisible), 354 guests, and 3 robots.
Topics128,162
Posts1,057,042
Members48,463
Hey Team!
I am new to the forums and these trucks. I have been restoring and building things for as long as I can remember, but this is my most ambitious project yet. I found a 49 GMC 1/2 ton in amazing shape just 1.5 hrs from my house and I had to have it.
So I am going to rip the truck down and rebuild it with a 350. In the interest of doing things hopefully as right as I can I want to start from the ground up.
I'm curious about a reasonable size of rim for these trucks. In my mind 18's with a reasonable side wall should give me a comfortable ride??
My main question though is what has everyone found to be the best suspension setup, this truck will be only highway and city driven. Do you leave the rear springs alone? Do you parallel them??
For the front I know the topic varies but this build is attempting a budget so I'm looking for recommendations of front suspension upgrades? No air but IFS setup for sure.
Please pour in the knowledge
DC
1949 GMC Half-Ton
Frame-off Resto-mod - 4.8L 4L80e
"Into the Nitty Gritty"
Follow the build in the DITY Gallery
The #1 thread on this Forum has a lot of good info on this subject. It has a sticky note so it always stays at the top. Check it out.🛠
Also go to the Tech Tips under Suspension and read the various tips there.🛠
It’s always good to search the site before asking questions. Many questions have been covered hundreds of times. Fun project, good luck.👍🏻
currently installing danforth cross member in my 1950 3100. I like it so far. fun installation. I can stay Chevy which i like.
haven't figured rear out . Thinking of tci leaf kit. Have used coil overs on other rods. coil over would let me adjust height easier
I just finished a 1946 chevy pickup street rod
now on a 1950 chevy 3100
also a GMC 220 with duals
and a 1948 chevy 2 ton
