5 members (2-Ton, Hotrod Lincoln, Jims46, Otto Skorzeny, Maybellene), 68 guests, and 6 robots.
Topics128,181
Posts1,057,152
Members48,464
Does anyone know a source for new Rear spring u bolts 1958 Viking 60 two ton? Have any of you changeged these out? While cleaning and painting chassis I realized the road salt and rust have eaten the diameter of them on lower end above the plate to about 3/4 s of original diameter. They look pretty rusted up and fused in place. Maybe quite a challenge
The 1958 TRI-FECTA
Stepside, Fleetside and Cameo
More Fleetside pix
More Cameo pix
More Apache Stepside pix
Try your local Semi-truck suspension repair/alignment place. Bet they have them.🛠
Yep, they make them to match while you wait, and should come with new thick hard washers and special tall nuts.
•1952 Chevrolet 3800 pickup
---All pictures---
Big Bolt Forum Moderator
diito on what Martin said. Here, the shop is Gitts springs. Take the old one in for a sample, they bend you new ones while you wait. 8-10$ a piece if I recall. I just had them do 8 for my 1951 travel trailer.
Mike
These guys can set you up. Good company.
http://www.stengelbros.com/u-bolts/
Lots more pictures
Thanks guys. I'll see what I can find here in deepeast Tex. Prob end up in Houston for semi truck shop.
The 1958 TRI-FECTA
More Fleetside pix
More Cameo pix
