0 members (),
70
Mod | | | Forums66 Topics128,179 Posts1,057,159 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 206 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 206 | Does anyone know a source for new Rear spring u bolts 1958 Viking 60 two ton? Have any of you changeged these out? While cleaning and painting chassis I realized the road salt and rust have eaten the diameter of them on lower end above the plate to about 3/4 s of original diameter. They look pretty rusted up and fused in place. Maybe quite a challenge | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Try your local Semi-truck suspension repair/alignment place. Bet they have them.ðŸ›
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Yep, they make them to match while you wait, and should come with new thick hard washers and special tall nuts. | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | diito on what Martin said. Here, the shop is Gitts springs. Take the old one in for a sample, they bend you new ones while you wait. 8-10$ a piece if I recall. I just had them do 8 for my 1951 travel trailer. | | | | | Joined: Nov 2005 Posts: 206 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 206 | Thanks guys. I'll see what I can find here in deepeast Tex. Prob end up in Houston for semi truck shop. | | |
