9 members (Gdads51, Rustnut, 3800GUY, KEVINSKI, Southerntruck, klhansen, dt235sd, Otto Skorzeny, Hotrod Lincoln), 69 guests, and 3 robots.
Topics128,079
Posts1,056,301
Members48,441
#1244048 11/20/2017 3:06 PM
I'm looking to get a parts truck for my 1962 C10, however if I'm unable to find a 60-62 C10, then would it be worth it to purchase a 63-66? I know that the 63-66 years have some differences, but I don't know if there would be enough differences to keep me from getting one.
College student trying to restore grandad's 62 C10
Depending on parts needed the differences could be significant enough. Check front of lmc catalog for quick reference and then compare year specs from the gmheritage site. Suspension and frame differences. Headlight config and hood obvious. But there are many similarities once you get beyond those areas
~ HB
1962 Chevrolet C10
1962 Suburban
Matt Skittles #1244197 11/22/2017 12:47 AM
V
V Offline
In 1964 the A post leans back instead of forward. Doors and windshield would not interchange.
Rich
Rich
68 C30 CST dually flatbed dump
58 Viking 6500
i have had both a '63 and a '62 C10. Here are some of my observations.
'62 was the last year for the X-Frame and torsion bar front suspension. So '63-'66 will not swap frame or front suspension. '62 rear end is a 3rd member drop out style. '63-'66 has the more modern style, does not swap internal parts at all, but may swap as a full housing/axle unit.
As stated above, the windshield, cab, and doors are different from '64-'66, but the '63 is still a match to the '62 on that score.
Other body parts, fenders, hood, bed, tailgate, etc.. do swap. Grills and grill surrounds do swap, but the grills are not physically the same as the '62. '60-'63 had single year production on their grills, different for each year. '64-'66 had the same grill for all 3 years, but different from the previous years.
Engines/transmissions can swap, but you need to be careful. If you have the I6 235, you will need to change the bell housing if you go to a later model I6 230/250/292 or a V8. The bolt pattern is different. Also different is the tranny mounts if you have a manual tranny. '62 has 2 mounts on the bell housing that are not there on '63 and later models which use a rear transmission mount.
These are just a few things I can think of off the top of my head.
Basically it boils down to "If you must buy a '63-'66 parts truck, get a '63. It is the best match of the '63-'66 series."
62Stick #1244442 11/24/2017 3:09 AM
I don't think that rear trans mount was used on manual trans until 68. p/glides used the rear trans mount from 60 -66 and the t400 in 66
ron
62Stick #1244537 11/25/2017 1:06 AM
Thanks a ton, that info is really helpful!
padresag #1244575 11/25/2017 9:18 AM
ron
Thanks for that info, my '63 had the Power Glide from the factory. I later swapped in a TH400, but had to move the rear transmission mount cross member rearward to match the new rear mount location.
